  • Replies 7.5k
Posted Images
Spotted a white 34 with no front number plate, didnt see anything else of the car so could be anyone LOL was on anzac h/w near hungry's. Bout 5.45, sumthing like that...
Also white 32 gts't going up south road near flinders, turned up shepherds hill road. bit dirty but looked nice. Was around 6 tonight.
Also 3 choppers and a plane trying to put out a fire near the xpressway.. goodluck fella's..
spotted that fire being just up the hill from me (yikes)
ummmmm an interesting black 32 gtst on brighton road.......bn kit, low as f**k at the rear and a white 34 gtr front end conversion
did u see that plane dropping the water on the fire?
Yeh saw it, was like WTF until it dropped the water.. Were 3 helicopters dropping water also and another one just flying around. Traffic was insane, glad i wasnt driving!
traffic was off the hook... with the freeway closed cos of the fire, big accident near the brighton road/seacombe rd intersection and a bunch of the light sequences changed on south road... the traffic was fkd to say the least
A 2 door with a tow bar?
or do you mean HR Pillarless sedan?
was a 2door
spotted a yellow Ford GT40 (or replica) this arvo cruising down Grenfell Rd, Wynn Vale - had Vic plates .... damn they are HOT!
the only V8 to have is a twin turbo GT40 :(
>>Joes GTtt 40<<
Matty any change of coming to see that wheel tomorrow after work or you don't finish till late
was a 2door
>>Joes GTtt 40<<
no dramas mate. Im goin to be in at tyrepower briefly afta work gettin tyres changed over for sunday, then gotta pick up a car trailer about 7pm from near mine. lemme kno either way, reckon ya have my number (if i remember i'll bring her into work with me and ya can catch me at tyrepower)
was driving along marion road with a silver 33 bout 1:40pm, not sure if they on here or not, sorry if my driving was erratic, crap day at work, eager to get home and impatient with other drivers lol
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
