Lol.
Piss off Ash.
I went down there on Tuesday and they were just about to start on it. I'll be down there tomorrow to drop off something so I'll see how they're going. I've got a week off work the week after next so I should have some decent progress there.
I've decided to give the -5's a run first, Atleast to get a baseline and to see how much of a difference this head has made.
I also got my balance tube back from HKS as they have ported it to suit the head. I'll put pics of that up when I get it back from Hypertune on Friday.
less faggotry more build thread!
Dave, I like it, no bullshit and straight to the point !!
Paul will never have this engine finished.
Infact this mystical japanese head doesn't even exist. He just copied some pictures from the depths of google
Ash , I can tell you its 100% for real as I had to lug the bloody thing in my carry on back from Jappa.
No I'm not Mike.
If you were would be a good basis for comparison to other results... we dont race flow benches (or dynos) but it is the only measuring stick we have to go by for heads.
ok, just caught up from like page 3 hahaha :D
as for your suspension, i don't think they'll be too firm if the shocks are up for it. I believe my Arragosta's are 14/12 kg springs which i was absolutely dreading, but really, they're fine on the road. So i reckon you're R-tunes will be fine...
in fact, man up... get some silly Jap rate springs in there! :D
Agreed and the best way to measure your gains with back to back dyno testing. I can't imagine the withdrawal symptoms u are experiencing Paul...almost there
Yeah getting there man. This thing is gonna cop the biggest raping of its life when its back together!
Yeah I know man, however it's so close to being put together that Im not going to take such a critical part away from the builder. Sick of waiting.... Need to be launching!
LOL
Well, i've had them in the car for a little bit (100 kms or so). They were firm but also compliant (if that makes sense). I'd it's the valving in them. I was expecting it to be 4 gum tree stumps in there. That was on 19's with 30 series tyres, so i'd hope to think that with a 265-285 35 x 18 tyre will help.... even if ever so slightly.
OK. Finally a little update
I got my balance tube back from HKS. That got ported and matched up to the port size and shape of my head
I took it out to Hypertune so it could get modified for whats called the "JUN cooling mod"... Well that seems to be the most common name for it.
Keen eyes will notice the 6 holes where the air would be have now been filled up and the water galleries have been tapped to accept a fitting. Out of each of these there will a -4 line that goes to a header tank. The wiring loom has to move so that will be rerun under the runners of the plenum.
Also there has been a camshaft change. Unigroup (Well Yavuz) went and picked a lobe that was much more aggresive than what the Japs have to offer.
Very nice paul. Good to see progress mang. I might take you up on that offer too mate. Ill call you about it tomorrow and we can organise something. Interested to see the camshafts too. Lift change? duration change?
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
