Cheers mate, i was looking into the kits last night coz i think it will be easier to just chuck in a 2.8 crank rods and pistons into my engine already as thats all id need to change instaed of going 3L.
you can re use the existing head studs and all that stuff right? just need new head gasket and bearings?
you won't regret going 2.8, I remember driving Paul's when it had the gt-rs's still on it and the bottom end torque was amazing, I actually made the comment that day "the only thing I'd change is put 2530s on it"
yeh in reality i should of done it when i built my motor 3 years ago.
its going to have a t51r strapped on the side of it so it should make it pretty fun ( not that its not fun atm lol)
We are still to sing whistling dixie down the freeway Chris! ;)
I know the feeling...done that!!
I always dummy fit first especially with new/modded/rebuilt turbo's.
It's too much of a pain to re-clock once they are in...
Well you would think when you took them down and said "reorientate to fit a GTR" you would expect them to fit!!!!!! :domokun: :domokun: :domokun: :domokun: :domokun: :domokun: :domokun: :domokun: :domokun: .
Bit of an update;
Got the turbos back this arvo, they said they were out by 10 degrees. Don't know if it was that much but they're fixed. The hot side is complete bar the turbo supports and one water line.
Tomorrow I pick up my balance tube and idle garbage from Hypertune. Too hard to explain so I'll take some pics what I've done.
wasnt it just a simple case of clocking the rear or front covers?
Not the point. I wasn't gonna sit there pulling shit on and off trying to get tr correct angle. I know what you're thinking "it ain't that hard". But with two of them that need to be the correct angle its a pain in arse.
Either way, how did it get messed up? Have a look at the 200 gtr turbos out the back and make it the same.
belt the crap outta it! be keen to see what the -5's can produce. Still got my dollars on the 470kw :)
Haha. It would be nice. I'll be stoked with 450 at a reasonable boost level.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
