For the sake of an update... An update.
Gates are on. Gate waste pipes are done for the most part. I put an 18.85 psi Spring combination in, mostly due to peer pressure (looking at you Micko)!! I was thinking 17.45.
Hypertune are doing some coolers on an R35 ATM and should be done hopefully next week. When ever it's done, I'm going in. That will be to fit up the cooler (no stock brackets line up anymore) and turbo to plenum piping done. Wiggins clamps (blown cooler pipes will be a distant memory) will be used on all joins apart from where it meets the manifold. I am not pulling that Nismo plenum off in the car. It's 15 times more painful to pull off than a stock one. If ever the motor is out, I'll put one on then.
Surge tank design is pretty much confirmed.
Really, the only thing missing from the puzzle is injectors but with the dollar, I'm putting off that purchase till when I need them.
The other week Reaper was around with his 8374 snailed NUR. It should go damn well on the stroker! Also, another mate is putting one on a 3.0 so it should make for a decent comparison.
18.85???
running yet or you doing a bobby on us
No mate.
It isn't at a shop. Micko is doing the fab work so it;s just a case of hipping away at it when we can.
With any luck, Hypertune may take the car in this week for the intake piping and cooler fitment.
  • 4 weeks later...
Hopefully goes to Hypertune tomorrow for turbo to plenum piping but I've heard that before!
Yeah yeah, turns out the rear turbo was cactus anyway. 5000 kms. Spose they didn't like to be run so hard so either way the turbos were coming off. Oil all through the dump.
