For the sake of an update... An update.
Gates are on. Gate waste pipes are done for the most part. I put an 18.85 psi Spring combination in, mostly due to peer pressure (looking at you Micko)!! I was thinking 17.45.
Hypertune are doing some coolers on an R35 ATM and should be done hopefully next week. When ever it's done, I'm going in. That will be to fit up the cooler (no stock brackets line up anymore) and turbo to plenum piping done. Wiggins clamps (blown cooler pipes will be a distant memory) will be used on all joins apart from where it meets the manifold. I am not pulling that Nismo plenum off in the car. It's 15 times more painful to pull off than a stock one. If ever the motor is out, I'll put one on then.
Surge tank design is pretty much confirmed.
Really, the only thing missing from the puzzle is injectors but with the dollar, I'm putting off that purchase till when I need them.
The other week Reaper was around with his 8374 snailed NUR. It should go damn well on the stroker! Also, another mate is putting one on a 3.0 so it should make for a decent comparison.
18.85???
running yet or you doing a bobby on us
No mate.
It isn't at a shop. Micko is doing the fab work so it;s just a case of hipping away at it when we can.
With any luck, Hypertune may take the car in this week for the intake piping and cooler fitment.
  • 4 weeks later...
Hopefully goes to Hypertune tomorrow for turbo to plenum piping but I've heard that before!
Yeah yeah, turns out the rear turbo was cactus anyway. 5000 kms. Spose they didn't like to be run so hard so either way the turbos were coming off. Oil all through the dump.
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
