Yeah, Wiggins. 5 in total. Blown cooler pipes are no longer (unless the plenum one pops). No more taking front bars off!
Thinking about painting the airbox black, cutting a hole in the top of it and using the factory airbox snorkel to feed the box too. Can't hurt!?
Silicone is good for 40 psi or so, you will be fine !
Looking GOOD brother!
I like how they ran your piping. Mine is out to the side to make room for the PS reservoir and such, but I like yours a lot. Hypertune is top-notch stuff! I am always leary of 100% solid connections to the coolers because it seems they might induce stress on the piping and turbo manifolds when the engine torques around, but they don't have anything that looks as sexy as that to be honest!
http://youtu.be/76CEWVXru3M
Have a look. They move around quite a fair bit. More than enough when all combined I'd say. :)
My fabricator is trying to talk me out of going aluminium piping, those pics just about sealed the deal for me :) looks great. I'll need to do some reading on these so called Wiggins clamps
There isn't much you need to know, they are bright purple and very racecar. Just open up your wallet and prepare for butthurt when you hear the price.
On topic, I cannot wait for this to be done. The EFR looks very at home in there that's for sure.
Adel Wiggins clamps. They're actually aviation gear but can be used in automotive applications also. They're a bit of a homo colour but they're that colour so plane guys can see them.
Make sure you're sitting down when you see the price.
What's wrong with alloy piping? Does he want to use stainless?
Yeah we use them at work (I work in an aviation environment) and they are used for everything. If they can handle bleed air straight from a turbine compressor (80+ psi and a couple of hundred degrees Celsius) then they should stop a cooler pipe coming off ;)
You should ask about having them lockwired piggaz. Just for some extra security/piece of mind.
Lock wired is a bit too much. I really can't see these blowing off with 30-35 psi considering they're rated to 150-200 psi or something. If they do then there would be another issue like a busted engine mount.
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
