40 minutes ago, ActionDan said:
Any of you guys follow Eribusu?
Making good power now and would be a hoot to drive with that Albins box in it.
Yes yes, not an RB, but f**k me, what a sweet car :D
I had seen it a couple of time, that green is mad , love it all  !
Yeah, Precision have things quite nicely stitched up for if you want over 600kw @ wheels and not too worried about how the car takes off under 5000rpm... that doesn't seem to be the target here though :)
Looking forward to seeing exactly how urgent this setup ends up, should be rather quite fun to punt around!
2 minutes ago, fatz said:
So much hate my 6262 was epic EPA silly on the track mid corner
I know they got trashed a bit above but I have no problem with them :)   My comment was not bagging them at all, actually complimenting them - just where there are EFR equivalents I'd rather the EFR from the experiences I've had so far.... saying they aren't as good as the best isn't the worst burn one could give!
  • Like 1
thus I mentioned 2-speed powerglide
