That is true.
Comparing his motor to mine is comparing apples to oranges.
I ran 134mph last time. Might crack 135-137mph on a cool night
Piggaz - is WSID on the cards in the next couple of weeks? Let me know if you go and I'll try to bring mine out on the same night.
3 minutes ago, usmair said:
That is true.
Not sure when I'm gonna get down there.
Need to spend a bit of time RE learning how to drive the thing, it's been a long time and a lot has changed.
Wheel alignment first before any dumb shit otherwise I'll end up in a cow paddock.
Sadly not however I have been inspired by this quest for "response bro"
sadly in the opposite way I want a laggy crack whore of a car to take to the track and thrash that's a prick to get a good time out of
think I am getting old and grumpy
1 hour ago, ActionDan said:
Dump is faggotry.
Fatz: do you have any fun cars at the moment?
That Corolla though...
Define fun... lol
i did do this for 24 hours with some mates last weekend in the 31
Have a half share in the charity rally 34 gt
which does epic skidz now it has 270rwk
and I do have a vq35 6 speed r33 gtst
bit I have a hole that needs filling
and that hole is a  Gtr
Ahh that's right, forgot about the 34 rally spec lol
I'm getting old, I want something a bit more refined but not something that looks like the 35 or sounds like the M4 [emoji32]
My 34 is sexy but may end up in a 35 down the track.
So you want T88 on a stock 2.6L with Type B Poncams lol
I'm getting old, I want something a bit more refined but not something that looks like the 35 or sounds like the M4 emoji32.png
I was close , 2.6 with the T78, built motor and stock cams, it was sensational as a DD !
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
