Hey Paul, as discussed - I used to run 044 in tank, changed to Walbro 460 for e85. Nearly kept up with demand but was on the edge and needed surge tank for track. I considered a number of "big single" fuel pumps - but most American gear I looked at had "duty constraints". ie not to be run at full duty for more than X minutes..
also, mixed results on 'noise' depending on who you talk to. Have sat in a few cars with Aeromotive, Maganflow etc that all you could hear is fuel pump.
this is ok if its a track car only - but to me, even a track car with a quiet pump means you can hear 'other stuff' that you want to hear.. so if you can get performance AND have a quiet pump - then why wouldn't you. Considered speed controlling these and even bought a Fuelab to do just this but did not go ahead based on other factors.
I think there is something to be said for OEM manufacturers. Generally cheaper (replaceable easily), reliable, often quieter, less amps draw (sometimes).
Running e85, I wanted no 'corrosion' so surge tank had to be completely anodised throughout. There is anodising and there is anodising. You want Type 3 Hard anodising done if you get it done locally - this stands up best but it is not 'by default' what you get - you must ask for it.
All lines are Speedflow Series 200 Teflon lined. No corrosion and no smell.
I ended up running a radium surge tank which is well made, properly anodised throughout and holds 2x Walbro 460 e85 pumps. Could have fabbed our own but why reinvent the wheel when this was a good solution. I only switch the second pump on under high load, so it sees very little duty (so it should out last the main one). With e85, there is much less chance of engine damage if you lean it out... and remember a big single pump can still 'slow down' over its life, so the argument there is.... arguable. At least when #2 pump fails you know about it. A big single slowing could catch you out over time.
regarding lift pumps, people have mentioned you can use another Walbro 460 for that - BUT, check out their current draw. They draw big amps even with no load or pressure.. about 10A from memory. If you are at full noise with all three pumps going at 20A + 20A +10A you can be drawing 50A for fuel pumps! (admittedly only at certain times)... with all the other gear we're running and CDI/fans etc... you want to keep it down where you can
I use an e85 rate Pierburg Lift Pump which only draws about 2A and easily keeps the surge topped up.
End result is I have a fuel system that you cannot hear even if you put your ear to it. It is capable of well more than my cars puts down in HP.
Parts are easy to get locally for replacement. All pumps are submersed in fuel - which I also believe keeps them happier in terms of temp and environment. ......and the surge tank is pretty to look at. Bonus. :)
  • Like 4
Sure - its one of the most bling things on my car actually. Normally its all about function and lightweight, but went a bit overboard with a CNC aluminium "shelf" to fit a lithium battery, the relays (hidden behind battery when installed), surge tank and holders for the canisters from the AST Suspension.
The surge tank can take up to 3x Walbro 460 e85.. I run just the two. Pierburg 2A Lift pump in tank.
  • Like 8
Hater! :)
I have a Mangafuel Protuner 625 that doesn't need PWM and doesn't have runtime restrictions (I have done hundreds of KM's then done 1000m drag runs without issue) but it's a noisy f**ker. I'm constantly considering the same option as our male model friend here, twin Walbro 460 pumps. I had one in my last green car when they first came out, fantastic pumps and almost silent.
Edited by SimonR32
That setup is mint, Matty.
As I said on the phone today, i've bought one of those Holley dominator 1800 pumps. By all accounts it should satisfy everything that gets thrown at it.
Bit of an update.
I finally got the car home. Huge issues with injector baskets filling up with this super fine silt. Its small enough to get through the 23 micron filters I have post pumps. The baskets have been cleaned about 6 times, fuel filters twice. The intank pump was flogged so a Walbro 460 went in as a lift pump. Definitely a whole fuel system clean out is in order. I have a few large 6 micron fuel filters coming also.
The modified transfer case has settled the car down alot too. With the GT Pro in the rear set to medium, it was very taily. It feels much more planted, can get on the loud pedal earlier. Win win!
The tune has been relaxed also. Boost controller is turned off, 3 degrees of timing taken out and 6-7% more fuel across the entire map just to make it super safe with this fuel problem. It still went onto make 415rwkw. Did a comp test and its 190 psi across all 6 pots.
The box is great. Definately "woke" it up. The clutch is better than expected also.
28268977-DC49-4393-B984-34533CC3DFAB_zps
What the intank sock looked like.
7A4194A9-20D1-4329-9304-B668EE32112A_zps
Bit of box porn.
  • Like 3
Dang. You make me think dumping this old wore-out box on the curb and getting a fresher, younger, but more expensive box that may let me thrash it more before complaining.
Wait...we aren't talking about wives?
  • Like 2
http://vid1068.photobucket.com/albums/u457/Ptriffitt/F690A0AE-CCD6-4CEF-A3DD-3D47EE493AFF_zps0mlky3ck.mp4
For shits and giggles I took a video of the warm idle just before the compression test. On E85 you would hardly know it has cams in it.
http://vid1068.photobucket.com/albums/u457/Ptriffitt/D2CDE898-D824-4475-8145-56E87DFD29A6_zpsu2e9b2mn.mp4
A bit of box action. 415 KW, 19 PSI, super relaxed tune.
  • Like 4
Well what can I say, your passenger said it all. :special:
Love that box , box Mmmmmmmmmmmm
  • Like 2
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
