Sau Vic 2012 Motorsport Championship Round 3 - Now With Entry Details
I'm out fellas. Enjoy. I emails Neil today. Unfortunately my new sump isn't quite doing the trick. Hope it's good weather out there for you guys.
I'm staying posted to make sure I get an entry into 21/7. NEED more testing time before WTAC.
  • Replies 159
Posted Images
woo PB...boo rain....day summarized for quite a few ppl.
:cheers:
Also don't forget a spin or two for some of us :yes:
Managed 3 session - one completely dry, one drizzly (PB 1:55.3223) and one completely wet. Really did not think PI is so slippery in wet.
I really struggled in wet, but it was also good practise to see how the car behaves.
PS: Funny story - walked up to an Alfa owner to tell him he's car is dripping some oil ............ he just look at me and laughed - guess its a standard feature.
Shame few of them broke down early in the day too, but AROCA run day was pretty slick ptherwise. Really liked the fast change between the groups, and reasonably long sessions.
:cheers:
Yeah was a very good day, we might look at doing some more of theirs next year.
I got same practice completely stuck in traffic so much no heat got in tires and thus could not get the pressure right for sprint.
first sprint, got clean track and a PB..tires got temp swung into pits to set pressure.
rain..
SLIDE SLIDE
soaking wet, but good to finally drive at the island.
were there any photographers out there braving the elements?
Thanks Ash,
Yeah we were out there, got quite a few of you guys getting sideways at one stage...will post up details ASAP.
It was just one of those days, blue skies in the morning. The promise of good things, dry run. Almost dry run, then rain and hail.
The air temp and track ambient were unbelievably low. I'm not sure of the apparent temperature, but is was fugging cold!
The track temp wasn't much better, even with the streeter tyres they where hardly warm after a session out on the track.
Had a blast, with good things to come as 49's come easy in traffic now.
AD08's are 13 track days old now as well ;)
LOL nice braking move by mr porsche at the end of the straight... wtf? was he afraid to take it a bit faster? Nice video and top driving as always John... gotta say, 1:49's on AD08's is awesome! what camera setup do you use now?
Photos up gents! (Click Here)
Use coupon code SAUVIC for a %10 discount valid until 10/7/2012.
Enjoy!
Thanks for posting up pics. The Mrs failed to take pics.
Thought I'd take it easy for first few laps. My car is there showing the swarm of mx5's that are unforgiving carnivores. Two side by side passing me on the inside of the hairpin!!
Had a blast.
Had a blast.
Did you fix the ignitor grounding issue?
Fixed the wiring but it seems to be coil packs or something electrical. RacePace have the car currently.... Now to find a GTR intake and FMIC and plumbing while it's there.....
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
