Anyone bought one of these Apexi pod filter kits that bolt on to the AFM and have a direct dyno comparisson to before and after, with nothing else changed other than the removal of the oe airbox and the fitting of the kit?
I'm considering buying one, but I'm not sure if it's worth it. Keen to hear of anyone's results.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/
  • Replies 65
Without a heatshield, it will cost you a tiny bit of power, with a proper heatshield and CAI it will make around the same amount of power as the airbox. The pod will make for a lot more induction noise than the airbox as well, up to you if you want that or not.
Check these vids out if you have a bit of spare time
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6363349
Mate there are many differing opinions, however if you put a pod filter on, the air intake capacity increases. You will see no gain by simply changing from standard intake to a pod. You need to improve airflow capacity from intake through to exhaust. Meaning if you have a larger exhaust from the turbo back then a pod filter will certainly help. The stanadard airbox alone is restricting air flow.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6363739
How will it increase airflow, by sucking hot air? Not filtering dust out? Pods usually have less surface area than the stock panel filter.
My opinions are based on experience. Stock airbox/cai ftw.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6363753
An old argument but do you have evidence for this? I am sure there is a point at which the stock airbox will become a restriction but I suspect it is somewhere way past 300kw.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6363789
I agree Bob, I guess it will flow well over 350, I know mine can and it uses the same panel filter. Save your coin for a good alloy intake and bellmouth dump/good exhaust. The tuner will take care of the rest.
If you want more power than that you would have to look at a twin pod setup and cai like this one I made for a mate's supra, it just put down 550kw last night.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6363807
CES racing have proved this with substantial evidence... Its interesting how these videos of proof by mighty car mods are hardly mighty mods. They use an R34 with pod then restricted air flow from the turbo to the cat to a cat back exhaust, that right there is pure wank factor to replace an exhaust from the cat back and leave the other half chocking your airflow. Then in the other video its the blue turd, this car is running a standard exhaust of course there will be no increase in power...
Hardly proves anything... The surface area of a panel filter may be greater than a pod but the shape of a pod causes a greater turbulence thus increasing the flow... The standard airbox was designed to restrict airflow to minimise the sound levels.
Why dont you just say that a larger exhaust will do nothing as well... If you believe that the exhaust being larger will increase power it only makes sense that an unrestricted air intake will help with the flow of air...
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6364072
Its true the above videos are not that scientific but they do represent what a lot of first time (especially Skyline) owners do - get a pod filter and a catback exhaust - closely followed by a noisy aftermarket bov.
Its not a matter of belief... its measurement that counts. There is plenty of research to show the optimum size of exhaust pipe required for different power levels. Similarly the size of air intake is important too and the restriction provided by the air filter ( I am assuming you do not advocate running with no airfilter on a street car) is minimal and the measured difference between pod and stock airfilters is even more minimal. The stock airbox and snorkel also has a small ram effect which helps with flow.
Do you have any evidence to support your assertion that "the shape of a pod causes a greater turbulence thus increasing airflow" (actually that's two assertions)?
When you are running a huge turbo that requires a 100mm or bigger intake then it can become impractical to use the stock airbox and you will need another form of cold air supply.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6364241
The airbox is unrestricted, its the intake that thins down to 40mm and requires upgrading. (not with the stock turbo though.) As Bob said, when you decide to build the engine, run a 3.5 inch exhaust with no cat and run a 600hp turbo, then you will need to look at the airbox being a restriction.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6364607
turbulent air actually has higher resistance compared to laminar flow, plus you run the risk of getting an uneven air flow over the maf
know much about reynolds numbers?
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6364610
Im sure my TO4Z dragging in air at 24lb would be creating a bit more turbulance than a little bit of wire in a POD, a POD is only a advantage if it has a heat shield and CAI on motors that need more unrestricted air flow, try doing a hydrometer test on the intake pipe to see any difference.
Results cannot be taken on the dyno, results need to be done whislt the car has the bonnet down on the road/track, if you want a accurate result do a hydrometer test, otherwise you are just pissing in the wind.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6364633
Why?
Close the bonnet and let the dyno fan run. The Mainline fan blows air at the car at 100km/h, which is exactly what you'd see on the road/track whilst driving at 100km/h; I dont see how its different.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6364642
I have a HKS Mushroom Pod. I don't have a lot of choice regarding the room I have - the cooler piping runs right through the place where the stock box sat.
I also made sure that I have a large amount of fresh air feeding it- up from the fnt bar. I don't really understand the HKS specific pod bashing. There may have been ones that fell apart after X years. Thats really not a good thing. But they do have a 3 layer filtration foam, its not just that coarse layer you see from the outside, which wouldn't filter well at all. Same quality as a panel? Probably not, but its not as hopeless as people make out.
As for temps- on the freeway / moving I've been seeing 22-25 degrees measured basically at the throttle body. My AFM is after the filter/turbo/intercooler. I'd say thats pretty acceptable, and its not sucking in hot air.
However, If I had a choice, it'd be to keep the stock airbox/panel. Getting a pod for the sake of it, just not worth it.
https://www.sau.com.au/forums/topic/400611-pod-filter-kit/#findComment-6364883
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
