I have just a few Nismo items on mine
Nismo front pipes
Nismo cat back exhaust
Nismo wheel nuts
Nismo tyre valves
Nismo twin plate clutch
Nismo braided clutch line
Nismo Dash and triple gauge
Nismo 400R side skirts
Nismo 400R rear bumper
Nismo floor mats
Nismo under car power bracing kit 8 piece
Nismo oil catch tank
Nismo intake piping kit
Nismo fuel pressure regulator
Nismo adjustable dual element wing (very rare)
Nismo carbon fibre wing end caps
Nismo 2 way diff
Nismo rear led lights
Nismo oil cap
Lots of awesome parts and pics!!!
I have (so far)
Nismo (obviously)
carbon wing end plates
engine and gearbox mounts
oil air separator
radiator cap
fuel pump
Super coppermix twin plate clutch, competition spec
Had Nismo 600cc injectors but changed to ID1000cc and to fault a Nismo part the IDs idle better
Beautiful car mate. :thumbsup:
Haha!
Thanks Dale but it's not my car (didn't have a pic of my car when I made the post).
I just posted it to show the Nismo kit.
Anyway, here's mine:
This.
To date I havnt seen a better body kit that I like more.
But, they really do need the rear pods to finish it and tie them in.
I know TBO and TRUST have made rear pods for the R32's.
But I used a set of rear pods from the R32 GTS-T and I believe they are from the Type M kit:
I have Nismo Front Bar and Side Skirts:
(But no bonnet / boot lip spoiler).
The Nismo kit is subtle and clean and tops off the R32 GTR nicely.
Also an Oil Cap:
Add a nice touch to the engine bay and you cannot over tighten the cap.
Had a Nismo Slave Cylinder:
Had to be replaced and now have a Nissan one.
So want that Radiator Cap!
Gimme gimme gimme!!! :D
That will be one of my next Nismo items I want.
Thats actually my photo of my Nismo r32 gtr! Its got a few Nismo parts on it too. Intercooler, fuel pump, 320km dash, fuel cap, oil cap, floor mats, gear knob. Think thats it. :rolleyes:
Looks great man!
You need Nismo LMGT4 wheels now :laugh:
A few Nismo goodies on my 32R...
LMGT4s
Wheel nuts (Black 7 sided ones)
Valve caps
Gear knob (slimline aluminium one)
Mats
Coppermix twin
Braided clutch line
Rad cap
Engine & gearbox mounts
Reinforced clutch pedal bracket (still to go on)
Nismo catback (just came off)
Nismo intercooler (ARC rebadged)
Nismo front bar
Nismo style carbon fibre intercooler air guide
Nismo style sideskirts
Nismo Logo Carabiner Key Holder :)
Would kill for one of those babies Terry, but they don't come up very often, and they only seem to be 33/34... let alone the drug money they command!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
