Not really Nismo but close enough but I had a no: 65 of the original first run GT500 "RRR" Block but its been recently sold and it's on a boat to Oz and will soon be with new owner.
Concensus = Terry, Chef man, and Marcus all not cool!
Have a few bits, but recently went looking for a genuine sticker like this one pictured As a replacement for mine on my boot lid in case i ever respray it (couple of little marks), and found them on yahoo JP for $80! One i saw had a price tag over $150!!
Oo old NISMO fetching a bit aye.
Really Ash? I had the full kit in a V35, including sway bars, and it was one of the best I've ever used. Of course the V35 was purely a street car with a few track days for good measure. But loved the ride in it and did all right at the track as well
I thought the Nismo Super GT Cars all used RRR Blocks..?
Hence it is a Nismo item...
Oh No Simon!
Surely not this one that my OCD took off your car on Sunday whilst you were out?
Don't worry! I put a rag in the hole!
I'd feel guilty otherwise...
Actually there's another recent version isn't there - looking somewhat like a - I dunno - a hub cap???
That black centred one of Richard looks you beaut tho'
That matches my radiator cap, do want....
More Nismo-Nuts on these last two pages...
I think "NISMO" could probably sell his User Name for a price ;)
I have an old-style Nismo Badge Luke that you're welcome to pick up. New too - but attached to a board!
If Luke doesn't want it, someone else can have it.
Meanwhile,...
...for an extra 15% air flow
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
