  • Replies 247
For the noobies, as Eric mentioned, this day isn't hard in tyres unless you choose to just do skids.
The last time MY R33 came up, I only used half the tread, and I left some pretty epic skids in 2nd and 3rd...
You will barely use any rubber if you're going for times.
PS: going for times is hell more fun as a driver, and if you drive well, even better to watch as a spectator then a boring smoke cloud!
Hopefully there is a spot left, i'll pay my entry now and where do i send the completed entry form???
also i need to fill out a SAU membership and a L2S licence, i can prefill them and hand them in on the morning or how do i got about that with payment etc???
thanks, Theo.
Hey Theo
once you have filled out the form and sent the payment you can either scan and PM it to me, email it to [email protected] or fax it to the number on the form (its there somewhere)
You can pre fill out the forms and bring exact (or close enough) cash on the day or if you want to do the same as above with the membership u can.
hope that answers ur questions,
Dave
Additional drivers are same pricing. We'll make arrangements so they can be riders in your car and you make two passes at the course, each driver back to back. Thirds create a logistical problem.
See me in the morning about your renewal. PM Goldzilla what merch you're after.
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
