Ok i have decided to put together a tutorial for installing new discs. i thought this might help a few people, so they dont make the same mistakes I once did.
Step one:
Once you have safely jacked the car up and removed the wheel, pull out the brake pads. If unsure about this, Click here , for brake pad replacement/removal tutorial.
Step two:
Find the two caliper bolts at the rear of the caliper (see pic.)
You may need a fairly long breaker bar to initially loosen the bolts as they are very tight. When you have removed the caliper from the mount be sure to rest it on a bench, on a suspension link (as in the picture) or just tie it up with string. It is important not to twist bend or hang the caliper by the brake line as it may damage the line.
Step three:
For the front disc it should easily slide off the hub.
For the rear disc it may be a little more difficult, sometimes fusing to the hub or the handbrake (drum brake inside disc) holding it in position.
Note: make sure the Handbrake is OFF or you will not be able to pull the disc off.
Using the threaded holes here screw in two bolts (M8x1.25) into the hole.
You will find they push the disc off the hub. After the initial bolt push the disc should simply slide off the hub and drum brake.
It should look like this:
Step Four:
Ensure you clean the new disc's braking surface with brake cleaner or paint thinner to remove the anti-rust lubricant the manufacturer applies for storage. This lubricant can contaminate pads and seriously effect braking.
Step Five:
Simply slide the new disc over the hub and into position.
Remember to fit rubber plug on the new disc. If your new disc didn’t come with one, just use the one from the old disc.
Step Six:
Gently slide the caliper back into position and tighten caliper bolts. (according to the R32 GTR manual 92-118Nm)
Step Seven:
slide brake pads back into position. Fit pins and clips. Sit in drivers seat and pump the brakes a few times until it feels firm again. Fit the wheel back on, and you are done!
I hope this helps a few people.
Ben.
https://www.sau.com.au/forums/topic/40346-brake-rotor-disc-installation/
  • 1 year later...
Thanks for this one !
Did my fronts (well one of em) yesterday using this tutorial.
Just thought I'd add one extra pic.
I did my fronts on the R33 GTS-T and found a couple of extra bolts to undo so you don't hurt you're brake line. (See piccie)
Pretty obvious what I mean, and they're not hard to undo...compared to those bugga caliper bolts !
THanks Bbenny!!! :)
I request this thread be stickied.
Good on you Birnie for finding it dude. I wish I had searched for it two weeks ago :(
Adjusting hand brake
If you are removing your discs it is probably a great time to check your handbrake. The R32 manual says to to:
Place the disc on the studs and fit wheel nuts so disc is secured to the hub.
(Give the adjuster a good blast with brakekleen)
Turn the adjuster from the top and towards the vehicle. ie. you are pushing the screwdriver into the top and it will click as it rotates away from you.
Once the disc is locked and immobilised, rotate the adjuster in the reverse direction for five or six clicks. I went with six as I would hate to have that drum rubbing
Replace the rubber plug and you're done.
You can then adjust the lever stroke with the nut under the handbrake in the centre console. It should fully engage in 6-8 clicks.
Cheers!
  • 9 months later...
should also be noted that if you are going to use old pads with new rotors, the pads should be faced so that they wear evenly on the rotor. it is best to put new pads and rotors on at the same time.
and they would probably need bedding in.
another tip to remember is make sure the hub and rotor surfaces are clean before you put the rotor back on. any grit, flakes of rust or any of that sort of shit between the rotor and the hub will give you runout and shudder problems in a short period of time.
  • 9 months later...
  • 3 months later...
Just a note on Handbrake adjusting I always find when i adjust a handbrake i slack off the handbrake end eg the end connected to the handbrake lever inside the car before adjusting it at the rears just something to think about really basically slack the lever end off then adjust the shoes out at the rear to the required amount then check for 6 clicks at the lever if not loosen or tighten until 6 clicks then it should all be setup correctly without rubbing on the drums etc :nyaanyaa:
  • 11 months later...
Is the whole 6 clicks thing a Nissan recommendation or just a forum thing?
I got my R33 with fairly low km (48,000) and at 58,000 now, my handbrake is tight on the 4th, bites on the 2nd, and generally holds on steep hills on the 3rd!
Is that a low km thing or adjusted different? As i have checked the clearance and it certainly doesnt rub when the handbrake is off.
If it doesn't rub, you're all set. IIRC 6 to 8 clicks is what's in the workshop manual.
when replacing a rotor, although it is recomended, do you actually need to replace rotors on both sides at the same time? for example i want to replace the front left only, does that mean i have to replace the front right as well?,
If you replace the front left only, you'll probably end up with uneven braking, as one caliper clamps before the other. With the left disc being new (ie. thicker) it'll meet the pad before the other side does. As you keep pressing your foot down to get the right side to clamp, it'll now be pressing harder on the left side, and so on. So you'll prob end up with the car steering left every time you hit the brakes.
It has been a while since I changed the brakes on my R32 but I don't remember there being any way to tighten one caliper in particular. You'd need to be able to offset the pistons, which you might be able to do when you bleed the brakes after changing the disc. Actually no, I don't think you can because you cant adjust individual calipers on a stock car.
Anyway, I highly recommend changing both, but I guess it depends on how worn the right side is. If the thickness is fairly close, you could be in luck. If you REALLY wanted to only change one, you could have the new one machined to reduce its thickness to match the right hand disc.
  • 9 months later...
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
