Torque figures above look right but I'd have to check my book. GTR would be tighter due to the metric superfine thread it uses (18x1.5) and the fact it's an 18mm bolt instead of a 16mm bolt in the 'lesser' models.
Remember boys and girls, it's all about correct tension, not lots of tension.
That 18mm bolt is definitely doing to need that much torque to apply the correct stretch to give it the exact preload it needs to never come off.
I've seen too many come loose recently....but come to think of it....all GTRs
The torque figure for an RB26 harmonic balancer bolt seems a little excessive... But its what the manual says.
The Torque figure for the 'lesser' models just doesn't seem like enough IMO.
my mechanic just got me a new r34 balancer through nissan for just over 400 buks... Cheaper then aftermarket
http://www.kudosmotorsports.com/catalog/nissan-harmonic-balancer-genuine-nissan-skyline-r33-r34-gtr-rb26dett-p-940.html
R33 and R34 GTR $421..
So the question on everyones lips (or mine) is what exactly makes them shit?
I can understand that newer designs/materials etc could make a better one - hence why I bought an ATI in the first place, but I am interested in why you say that - how does one 'measure' how well one damper is compared to another without some pretty special equipment?
ie something in your experience must have lead you to this?
Yes, I took a balancer off, turned it around and saw it had cracked through 90% of the rubber damper and thought to myself....ohh, that's shit. I'd better replace that shit balancer
They aren't shit due to material/design. They are shit due to age. Rubber doesn't last forever and when people realise that half the reason they are breaking oil pumps or damaging engines is due to their stock balancer, they will all start running out to buy one. Sean revs his GTR to 10k, 600hp at the wheels and drives it like a stolen VL. Still going 2.5 years later......but then again, he can tune good too
If you could pick only 3 things to modify in the engine of a GTR to make it near bulletproof at 600-800hp it's : 2. Billet oil pump gear 3. Good aftermarket harmonic balancer
We have proven it many many times.
This is what I’ve always found interesting point of discussion :)
I have neither of the above on any of my motors in the last 8 years (3 now). Nor do most others down here, with plenty of cars in the 370-420rwkw range so not just luck, all see regular track work with 8200-8400rpm limit and 200km/h+
Never throw belts using OEM Nissan. Gates ones were causing problems and also Daikin (I think?? going back a few years now when i spat 2 of them in 100kms).
(I’ll find out if new Nissan balancers get used in the builds, I suspect the answer will be yes)
...you know.... that hurts a little. I brought it on myself, but still.. where's the love.
Well to be fair, the only event we competed against eachother in, you beat me convincingly.. so... :3some: feel the love ;)
Only difference between the R32 and R33/R34 GTR balancers is the offset of the power steering pulley.
The power steering pulley R32 balancer protrudes a little further.
If you have an R32 power steering pump (hydraulic Hicas) Then you must use an R32 balancer.
Using the incorrect balancer for a specific pump will cause belts to be throen as the pulleys are mis-aligned.
Do you know how much further the r32 gtr comes forward compared to r33/34?
R32gtst pump/ bracket sits 10mm further back than r32 gtr
I have a theory.... Might be incorrect... but,
talking to the bloke that blue printed my crank, he said to bead blast the coating off where belt runs, and machine the front lip down... Apparently it will help alot.
Does make sense, see old machinery uses a flat belt drive (1920's) and the belt climbs to the highest point on the roller/pulley, so I figure the tall lip actually works against us in making the belt climb up it, so try this I will...
Does it have to be oem nissan or a standard gates one or the like?
And How tight helps for p/s belt? normal tight or uber tight?
To illustrate what Dan was saying, here's a table that shows how bolt class, thread pitch and diameter effect required torque. Notice the effect of lubing the thread, so pay attention to whether the shop manual is instructing you to use engine oil on the bolt (eg flywheel bolts),
http://www.cncexpo.c...ltTorqueNm.aspx
the japs said to me years ago, good balancer number one priority.. New oem at minimum and a really high rev limit (8800 if you look at any jap remap or decent shop tune) so you dont hit it accidentally... problem is here plebs seem to think the rev limiter is a gear change light... so its not that easy :)
This man, he knows!
So what ballancer do the japs recommend or use as prefference.?
In regards to rev limit, do you mean set it real high so you dont hit it?
What happens if you manage to get it to spin to the higher limit, wouldnt that be worse?
Edited by sky30
Another option is to pull a whole heap of timing out a few hundred RPM before the cut. That way if you do it it, it's not 'as hard'.
Oorrr just don't be a muppet and avoid it anyway.
Hitting rev limiter is not good for an engine. Hence why the japs set the limit so high so that the chances of hitting rev limiter are lower.
Does anyone know the thread size, pitch and tensile grade of the harmonic balancer bolt for an RB25?
Who uses loktite to do these bolts up. I know the manual makes no reference to using a lubricant on the thread when torquing nor does it say to use loktite.
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
