So i've had this a few times now, most recently the last couple of days. S2 R33 rb25det automatique', mostly stock- fmic, exhaust, 3deg retard on cam gear, iridium plugs in whatever stock range is, 6 or something,& tomei fuel pump. Not really been driving the car at all except to and from work in peak hour for the last week, alot of idling time and light throttle. Car started running and idling like ass, coughing/spluttering like it had lung-aids or something. Boost gauge drops from idling around -81 to -65 whenever this happens. I'm madly checking for vac leaks, misfiring coils, faulty cas, afm, oxy etc, can't find anything. So I take it out and cain the crap out of it tonight with a few full throttle runs and basically giving it a bit on an extended drive, and what do you know, back to pulling -81 at idle and running much better.I'm putting it down to fouled plugs or maybe injectors overdue for a clean....So this is what the rb25's love, a good bit of throttle, none of this touchy feely treat me gently shite?
https://www.sau.com.au/forums/topic/404704-rb25dets-love-being-cained/
They love it in and around their intake
that would explain the....buildup...... that i've seen in the intake manifold
my guess is you were driving it like a nancy boy and the car was rejecting you
I treat my cars like I treat your mum...get inside her twice a day and take her to heaven and hell and back..
oh man....it's obviously not impressing your car, check the light on the ecu, it'll be flashing pink, which is the nancy fault
i have got nearly same issue but car turns off when on idle like as soon as i push the clutch this happens when hot, i have friends saying injectors need a clean and new spark plugs because they would be rot from too much heat because of the injectors that are stuffed car sounding like shit atm. i drive the like pretty much like nancy boy every day but give it a flog once in a while lolz but no time to take it out but it couldnt be because of that?
if you hit the shit out of your turbo with a cane at least 3 times a week it'll make the motor stronger and might even net you some kw
Im guessing thats an asian father type encouragement
*hit him with book to make him smarter*
*whip him with caine like animal to make him faster*
I understand.
atmo blow off valve is your trouble buddy
when i was a kid in school, id ask my asian friends why they flog me in the maths tests
they said coz their dads would flog them with the maths text book if they didnt
aint no dictionary big enough to have fixed that test tho, fkrs.
so anyway back on T for this mofo. So the next day car was running like shite again...pulled the plugs and no signs of fouling, in fact some might say a little toooo clean. Gave it the ol' rev-ism a bit more and all good so I have NFI. Anyway have dude coming to clean injectors so will see if that makes sweet f/a difference.
i fixed my car turning off issue and it was the coilpack harness now it just sounds like shit car all shakeing and stuff please let me know if it ur injectors because i will also get mien clean but i think i got exhaust leaks i think i should fix that o2 sensor off the cat first, so if your injector clean dont work try a different coil pack harness, i only noticed because car seemed like it was searching for something like you hear slight rev change on idle, after the coilpack harness change i havent got that issue and it doesnt shut off on me no more :D
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
