Skyline r34 gtt (rb25det neo)
I just installed some tomei poncams type b 260 degrees 9.15mm lift and as stated by tomei no need to upgrade the valve springs.
i also installed the adj cam gears but only the exhaust side would fit, intake cam gear didnt match the intake camshaft. so i just used one old and one new
the timing is perfect and the knock is only on idle and coming from the exhaust side.
at first i thought it was the CAS but not too sure.
im running stock afm and injectors at the moment but will upgrade once the knock has gone and it hasnt been tuned yet but that shouldnt cause a knock.
any help or suggestions would be much appreciated.
https://www.sau.com.au/forums/topic/404757-tomei-poncams-type-b-engine-knock/
If its an r34 neo engine, it has solid lifters
This!!
They should be a drop in application, if you have done that and have the Ex gear set right it should be fine... Mine are sweet :)
This!!
Just for future reference, whilst they may "drop in", valve clearances should be checked and re-shimmed as required.
Yep, nissans clearances will be a better guide. and 'close enough' isn't good enough either keep in mind too much it'll slap the valve up and slam it on seat, too little and the valve wont get enough time on the seat to cool.
Actually the initial/final ramp rate has a lot to do with choosing clearances.
Having said that, going from Nissan's 0.2 - 0.25 sort of clearance to the 0.45 territory suggested by Tomei sounds like madness. You might add 0.05, not more than double.
Edited by GTSBoy
Don't trust those stickers, as part of compliance there has to be a sticker mentioning timing, clearances etc. Well mine says BTC of 15degrees (RB25), which if you know RB26's actually run a BTC of 20 degrees.
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
