Hey guys,
Unfortunatley was out with a mate tonight and got defected at Penrith. Cops are everywhere out that way, and they have a full RTA inspection setup.
Now issue is that he read 104 DB and the legal limit is 90. What we need is an exhaust to borrow to pass. We're happy to pickup/drop off and also swing some cash your way. If not, anybody know how we can make it legal easily and cheaply?
Car has -5's and 2.8 stroker etc etc.
Also he got defected on height and he has stock shocks/springs. Is there any adjustment from stock?
Thanks,
Aaron
https://www.sau.com.au/forums/topic/405138-exhaust-to-pass-emissions/
If the car is too low with stock suspension, then it is either stuffed (sagged old springs) or someone has done something really dodgy. The other alternative is that the car is not actually too low, and the cop is a dickhead and has just written the defect up hoping that other things will turn up at inspection. The other alternative is that the car has a stupid body kit or low hanging exhaust. That would be deserving of the defect.
If you want a cheat for the exhaust, make a plat to go between flanges that has a number of 10mm holes drilled in it. The more holes, the more noise and the more gas will pass through. Too few holes will choke the motor so you can't drive it. You do the work/math to determine what you need to get it mobile and passable.
Just went through this 2 weeks ago.
Be aware that they will not only test your exhaust DB reading, but also pop the bonnet and sus out things like atmo bov, uncovered air filter(heat sheild is not legal), atmo catch can etc etc that they will fail you on.
They also put the car up on the hoist and go over the exhaust system to see if its been tampered with. Its all documented and pics are taken.
They will note that exhaust bolts and been recently un-done/done up from fresh marks, dirty hand prints showing its been 'tampered' with. The guy in Granville was pedantic with it all and reasonably cluey. You can't pay extra to 'just pass it', its not like the dodgy pinks and blues people get.
Rumor has it, the guy in campbelltown is more 'forgiving.' So will try him next time.
However, even that he knew it was tampered with, at the time he did the test, the exhaust was under the limit and nothing caught his eye that was illegal so he passed it, but again took pics of everything.
oh and the plate with holes in it, between a flange works a treat. Just be sure to make it looks as close as you can to a gasket.
Hey guys,
Thanks,
Aaron
Where in Penrith was this?
Edited by cherring
Lucky i didn't fit one then lol, I was thinking of mounting one between cat and rear muffler as they sound a bit hissy on the rear, I guess i thought maybe the cops wouldn't defect it if it wasn't noisy and then not have to go through all the hassle, but I figured they would be onto it in the end!
That clown in Granville Failed my exhaust becasue the silencer was not welded in, Therefore not part of the exhaust and a hazard.
Had to pay for that, then come back again after a shitty weld job and back to get tested again,
He didnet check anything for tampering, I had the flanged closed ect ect
Far out Sydney has gotten bad. Can't even drive your car around down there anymore.
Gotta be stressing to drive anywhere near Sydney now. We don't have these issues on the coast..... Yet!!
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
