Entries Open: Import Monster Sauvic Deca Motorkhana - September 8 2012
  • Replies 343
Just transfered payment, $50 as its my first time at deca, and im about to fax through the entry forms and transfer document,
Pumped!
Welcome! Will be good to see you there :D
I love a good S vs R debate. Sometimes its just easier to let results do the talking tho.
List is updated. Keep them coming, good to see lots of new names! Dont let the trash talking put you off, its all just fun.
hey there!
I am really keen on doing this day, i think it's about time i actually got into learning the limits of my car and get myself ready for drift
I was just wondering if spots were still available.. and how i go about becoming an SAU member.. and if I am not a member can I still do the day?
cheers :)
Don't need to be a member to compete. All the rest of the info is on the first page of this thread. Enjoy
yep but is it still $50 for first timers if you are not a paid member of sau?
cheers
Nup. That offer is only for Vic Members apparently. Which doesnt make a whole heap of sense for truly new forum members, but hey, $85 is still spare change! and for the amount of fun youll have theres nothing better than Deca!
this is true, thank you :)
hope to see more girls entering as well!
cheers :)
Becoming an SAU VIC member is easy:
http://www.sauvic.com.au/sauvic_app
Save yourself $35 off the DECA entry
Benefits you get will more than likely outweigh the yearly membership fees.
And I'm sure we will process it before DECA :)
SAU VIC are running the DECA day and to give something back to new SAU VIC members, we are provide them with a way to use and learn their vehicles in a safe, controlled and friendly environment. SAU VIC membership also opens up discounts for further track based learning at Driver Dynamics events, not mentioning the other discounts and club related activities that go along with SAU VIC membership.
Join up, hope to see you around :ph34r:
thank you!
just filling it in now, cheers :)
Yes benefits like the Mt Buller Cruise
thank you!
Good to see you are actually entering, but I won't believe this until I see your name on the entry list jacqui ha ha
Guest
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
