After having some serious trans perfomance issues, it was found to be travelling in "safe mode" ie 3rd & reverse gear only
so I followed the recommendation of some SA forum members & took my baby to Michael @ MV Perfomance Automatics
...it required a shift solenoid set to fix the non-selecting gear problem & I agreed to a shift "improver kit" (quick shift) as well.
It cost $390 for the Shift Solenoid Set (that Nissans wanted almost $900 for) & $350 for the Shift Improver Kit + the trans fluid & gaskets etc $75.
Now I am a seriously OLD fella but far out, I can not believe the extraordinary difference in it's performance !!
it is frigg'n AWESOME !!!!.... it is a totally different car.
If you have not put a quick shift in your auto yet, do it ! It is the best $400 you will ever spend.
OLD Mark
  • Like 1
https://www.sau.com.au/forums/topic/409131-c34-auto-trans-quick-shift-kit/
living just 5 minutes down the road from MV, your giving me good reason to do this. Must say with most makes/models I have had with autos - MV has always been the first reference anyone has given - top guys.
Indeed Aaron...he does different "levels" of the shift kit ranging from softer gear changes to "slamming" into gear for high performance & drag cars.
I am OLD & just wanted the "softest" change....now there is immediate, no flarring changes & the box is immediately receptive to the increase & decrease
in revs...it is how it responds rather than the type of response that changes. HOWEVER, when I change over to manual control on the steering
wheel, it feels just like a manual box change...unreal !
It actually feels like I have a bigger turbo kicking it...the immediate gear change response is that good...all for $400
"the OLD fella"
Had one done in an RS a while ago and it blew my mind how it changed the car, better shifting into lock up mode when cruising and better oil flow to the back of the box. I wouldnt bother getting under the car for myself, Id go straight to MV.... as I intend to with the current RS$...lntentional typO
Hey guys
i live in syd but am very keen to get a quick
shift kit 4 my rs.seems like a cheap cost for massive
improvement.is there anyone that has had the kit put
in here in syd? Or know where to source the kit from?
Cheers boys
  • Like 1
  • 8 months later...
  • 3 weeks later...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
