So they will bolt onto any size pipe and handle over 300rwkw and is cheaper than a Z32. Next question, how hard is it to get it to work with power fc, I'm guessing not to bad just a matter of playing with the settings, but have no idea how to do this
Would be interested if my Z32 decides to die so I can do a full 4" intake
They aren't bolt in, you'd need to fab up a custom insert for them. Have a look @ his pictures in the first post - you can see the fab'd pipe as the sensor is a rectangle about the size of a matchbox (roughly).
I can supply the pipe sensor and plug for $250 only got 3 though
making it bolt on replacement for a z32 unless you wanna go bigger pipe
that would require a different size silicon adaptor i.e easy as
or even better make a proper inlet size which matches the turbo inlet size
so it doesn't have to step down like when running a z32
Edited by 1400r
Once you have an airflow map for it, it'd be a piece of cake to setup with a PFC. Getting the map would be the hard part.
Yeah that's what i thought. No idea who could provide/work that out but. Will see what happens with it anyway
I'll say it again nisstune have the map support the people testing this stuff out guys
anyone supplying nisstune should be have access to the map via Pete and Matt (nisstune)
and you can get the adaptors sensor kit from me :)
Edited by 1400r
Yes....but the VQ map will be different for each different size tube that the sensor gets installed into. To be clever, you would even want to know down to about 0.5mm that the ID of the pipe person X was using was the same as the ID of the pipe that person Y worked out a map for.
If you were lucky, you could just scale the mass flow from one size to another by simple cross sectional area....but given how non-linear these AFMs are known to be (not R35 in particular, but all hot wire meters) I'd be wary of doing so without proof.
This is not an objection to the idea, just a warning that there is an extra obstacle or two to negotiate along the way.
nisstune didn't seem to think there will be no problem after playing with the vq map on mine
compared to the Japanese one I got and sold to them (the id'd were different slightly)
I sure if you used Pete to help along with your normal local nisstune tuner you 'd be fine
Yeah I know, thats not a problem. Just easier to fab into a 4" pipe rather then hacking up a Z32 AFM thats worth more apparently and then fitting that into a 4" pipe
Theres a few kinks to work out in this plan by the looks of it, but it shows some promise
Yeah true. Not really hard to chop a Z32, it's only plastic :)
Problem as already said is then getting the mapping sorted really based on the piping size. Potentially could cost you more in tuning/testing to do it as opposed with going the known option at this point.
I know this is a bit further along - Wonder what the life span of a R35 AFM will be hehe :)
Might look into it when someone works out the mapping etc in a 4" pipe, as you said its at more of a devlopment stage at the moment and with a half built engine and a shrinking list of dyno's where I live, I certainly dont want to put money into it at the moment lol. The Z32 AFM will do the job nicely for the moment :)
HOPEFULLY, it turns into a good option. But until a few people start using them I think OP will be met with alot of the same. It's to early for most to commit, especially those running higher HP
Yeah its early days yet and the initial results are too odd to be convincing.
If it is anything like the VQ afm's... They have a microprocessor inside them and fail regularly.
:yes:
They certainly seem to be easier to remap from reading i did a while back, most likely then means they are the same (or similar) to a VQ style
Wonder if anyone has pulled down a R35 AFM and can confirm?!?!?
Hence is this a case of brining more problems into the system for the sake of $150 if they are going to have more issues.
yep mate stick to what you know seems you weren't a fan of the idea to start with
ps I can supply match pipe 3-4 inch all fab'd up
however I would prefer to do this once I've tested them on my mates 380rwkw rb25
so I now if there is any issues
selling the 3 3 inch ones I have first before outlaying more of my cash
I would be well surprised if they have microprocessor in the afm... May have some kind of signal processing. I know the output is just a typical 0-5v output.
As for tuning i wouldn't be setting it up on a 380kw car - I would get a fairly un modified car and try to map out the bottom end of the curve.
Edited by rob82
I've already done the ground work with getting my car retuned to suit the 35 gtr afm mate it makes just under 200rwkw
point is in a 80mm pipe (matching z32 size pipe) they max out at 300rwkw
so I want to test them in my mates car with nisstune as it makes enough power to top out the afm in 80mm size
to make sure the theory of upsizing the pipe size actually works without driveability issues
not doing anything till I sell the 80mm units I have though already sunk enough cash into testing
It should work well in a larger pipe if you can re-program the voltage curve and retune for it.
It must adjust the airflow signal dependant on temp as the iat sensor is built in, perhaps even pressure? (This is a VQ25det afm.)
I always thought Nissan were a little mad to use the pre turbo temp signal from the afm for correction, especially as the Stagea runs 1 bar stock.
If there were no calculations going on inside there would be no reason to complicate the sensor with the electronics. What is the failure rate of the GTR afm's now they are getting older?
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
