1 hour ago, ActionDan said:
Stock bottom?! Wasn't it done with the $$$$$ head?
Assumed stock box would be removed as nobody would expect it to last behind anything decent, especially a 6spd.
"Apparently" the same type of Aisin AZ6 gear box that's in my 86
Rated to 250nm
I learn something new every day!!!
Stock bottom will go bang with 400kW+
Box will die easily with 250kW with a few laps at Wakefield.
S15 bottom will do 320 to 340kW with torque being limited either via timing or boost control strategies.
Should do a 5 speed swap using a R33/34 RB25 turbo box.
None of my cars will be seeing the track, I'd rather just enjoy the cars every now & then.
That's enough for me, I'm not a millionaire to be able to afford track days or risk losing everything.
I'll have to assess the gearbox stage carefully.  My money can go so much further on travel around South America, so Id rather ignore a gearbox solution as long as possible.
What do you mean no track? ;)
On 6/1/2019 at 11:43 AM, BakemonoRicer said:
Haha I’ll float the car to Adelaide and line you up on the circuit mate. We can put $5000 on it to make it worthwhile. You’ll probably get crossed up trying to match my late braking & end up in a tyre barrier, so when I win you shall refer to me as “The Don” and comment my thread admitting the car is a museum piece
  • Like 2
  • Haha 3
  • 4 months later...
Overr the christmas holidays I decided to get stuck in and work on the car. Started off with reinstalling the bonnet & mocking up the front bar. Installed a big spec Cusco Swaybar setup. I was really pedantic on making sure its completely equal each side, so measured off the chassis rails until it was exact (a step most people miss for the front which can be done wrong very easily). Swaybar was installed with the wheels loaded on the ground, and all new OEM endlinks & endlink bushes.
Next step was to sort out the interior, so I worked on running all the sensors for the DEFI gauge & the positive battery cable to the boot. Aligned everything real nice & it was back to looking like it'd never been taken out.
The engine bay is really starting to come together, the next step is to get the car towed to TRP for another don mega fuel system, then get it wired & Emtron'ed...I'd like to think I'm only a few months away from having the badger up & running.....
  • Like 1
Good work.
What shocks are in it? I found that my car had a lot more grip opn stock sway bars, with a whiteline in the front and GT-R in the rear it was full flat cap drift spec and just wanted to slide everywhere and would not transition weight smoothly.
Could be because it has those cheapo BC golds in it, firm spring etc.
  • 1 month later...
Bought another Emtron KV8 last weekend LOL. So now it's simply Fuel System, Wiring & Tune to go.
Dan, the coilovers are HKS Hipermax III 6kg F/4kg R. The Ohlins in the GTR kill them in every department, but that's comparing apples with oranges really.
MLR, no the swaybars aren't adjustable.
I had those in my first GT-R, the Hypermax, I quite liked them.
Keep some stock sway bars on hand for tuning the setup, you might find it's too stiff to put power down cleanly.
Good to see some progress again. Nice work.
Why dude? You have a gearbox that is lucky to survive with the stock turbo bolted onto it. f**k the 6 speed in your car makes a WRX gearbox  look strong!
You have a stock motor that will be able to be turned up to what 270kw max? Throw a single 525 in the tank and put your money to better use dude. You won't even need E85 for that kinda power with the 7670.
My car was at the power/torque limit of the motor at E15 dude so theres no way you are gunna be near those numbers lol. Dexter said you are out of motor that's it.
You do know Scott WILL NOT push the limit of a stock motor. Take it from me i know! He will give you whatever he feels is safe and that's it.
I really struggle to see your logic in these $4-5k Don Mega fuel setups for a million kw when you literally need a $250 single in tank pump to start enjoying this car?
Put your money towards a gearbox, a diff and at least some Evo calipers to help this thing put the power down and stop...
I can assure you it won't make it off the dyno with that 6 speed mate & you know it. The fuel system money is literally your gearbox & diff almost paid for.. Then theres the other bills you dont see like the tow truck back to Rigoli & the dyno time you will pay for with an incomplete tune.
THEN pay for another tow back and the tune to be finished. Give the tuner a car setup properly so it goes on the dyno and gets driven home not 1 that that leaves on a tow truck for repairs cos it's broken!
It's a beautiful car with all the cream dude why hold it back with shitty stock parts for junk that you simply DO NOT NEED ?‍♂️
Edited by Mick_o
  • Like 5
^ Completely agree.
My fuel system won't be anywhere near the Don Mega Spec stuff and my SR will make a fair chunk more power and be used in harsher conditions - and happily.
No way would I attempt 300kW on a 6spd box either. A 5spd might barely hang on with really gentle shifts and soft torque ramping but realistically you need to budget for a Z32/RB25 or better yet CD009 (if you want manual).
Edited by ActionDan
Much agree with Mick_o but i like the Don mega spirit as long as im not paying.
So to complement the Don mega fuel system, how about a Don mega gearbox (samsonas, hollinger, ppg, albins, tti, etc. choose your flavour). Run your 300rwkw+ without gearbox explosion at any time hanging over your head. That would be Don mega, not to mention f**ken quick.
Finish off with number plate
THE DON
DON MEG
DONMEGA
DONE
It needs the fuel system that’s what makes the power it has to be delivered efficiently to quench the thirst of the big port head! Already stripped the stock pea shooter hard lines out its time for the Teflon don upspec. Fuel pumps, flex sensor and custom alloy surge and hat all done.
Gearbox is the only weak link, if I blow the 6 speed That’ll get turfed for an AL’s RACEGLIDE!!!!!!!!
  • Confused 1
lol, no Benny. It does not need that fuel system to suppotrt 300rwkw - regardless of what's in the head.
We've been down this road before though, you get an idea in your head and it's very hard to convince you so just go ahead and waste the money, no skin of our noses :)
1× 525 Walbro supports my tiny 325awkw on E85 dude. So it will support your 260rwkw on 98 just fine.
If I was you I would call Al and give him a deposit on that glide now so that way it's ready to be swapped out on the dyno. Hopefully the box lives long enough for at least 1 power run for that dyno sheet ?
  • Like 1
You guys just don't get it.
Those pumps only work for you because you don't have a Don mega flow head from Naprec.
Sure, the combo is going to be dialed down to help the bottom end live, but big heads need big fuel. Even if 80% of it is being returned to the tank.
The higher flowing fuel in the rail just makes everything smoother and better.
Duh.
  • Like 1
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
