Another strange question from me.. I have googled, and found nothing that answered my question.
I still haven't assessed if I have a high flow or not. Doesn't matter. What a mate of mine did point out, is how loud my turbo is. You can hear the whistle (duh). But, inside the car, you can hear the turbo sucking in air seriously loud. Is this normal? Do others do this? Standard, high flowed? Etc? Is it gon' die?
I did spend the last 20min odd on youtoob, and couldn't find another boat owner with the same noise.
HALP thanks.
Being thinking about something similar..
Ive got a couple questions.. Without using pods what would make induction noise louder? and Would a metal intake kit with standard air box make the induction noise louder? I would love to get a pagani huayra sound in my car lol
It's all to do with the pod, and the type of pod. Some pods have more noise associated than others - whether its because of the level of filtration, or the actual construction metal vs plastic etc) who knows, not really a point anyone would probably care to look into.
Pod - lots induction noise
airbox/enclosed pod - less induction noise
GTRs make a bit more because of the side intake.
Take it to a shop that deals with these cars everyday and ask them to drive it. Any decent shop will be happy to take 5 minutes to tell you if it's normal or not. If its super loud it's probably not normal. A bit of noise is normal when you have a pod though. Better to be safe than sorry and what harm can it do to have it checked by a professional?
in my experience a poded R33 has mega induction noise. I originally had a K&N which was incredibly loud, I changed to a HKS shroom and the noise changed a lot. much quieter.
The stock RB25 turbo makes a silly amount of noise with a pod filter. In my old R32 it was by far the loudest, The Apexi AX53B70 made next to no noise and the 3076R made more of a whistle, but nothing seems to match the stocker for sounding like a vaccume cleaner! lol
Yeah i found the pod, split dump etc on my high flow was super spoolage! With a bit of Ztutututu just for Josh.............
The 3076 does spool loud followed by epic whistle and then lots of GAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAATE :woot:
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
