Hey mate
You got a Radiator overflow tank forsale
Is that the coolant reservoir bottle?
Cheers ben
pretty sure i have one floating around 20 bux plus postage, if you still need it flick me a pm
rear seats postage to toowoomba 4350 please. got any fronts without tears in them??
or even better any 33gtr seats
will get back to you with the quote shortly, only front seats i have are the ones in the first post
near impossible to get them without tears
  • Replies 148
Hey mate. Do you have the exhaust pipe clamp. Its the bracket that bolts to the gearbox and the cat with a small rubber insulator!?
What's the condition of the trans crossmember??
no exhaust clamp, crossmember is in good nick
hey fatz, i know yo have alot of $hit up there lol. Im after a throttle cable to suit forward facing plenum for my rb20. Wondering if you kept the one out of your last gtst you wrecked with that rb25. cheers
Console surround sold yet? if not how much to 3037
you mean stereo surround? I do have one but it has a small crack which is unnoticeable when mounted $45 posted
nah don't have one mate
Hey mate,
Still have the indicator stalk??
Is it all functioning?? (high beam??)
If so how much for delivery to 2906.
Cheers
Surprisingly they are all gone now
Sorry I have chucked about 10 of those out
Hey fatz,
Would you be willing to post the radiator to Wagga Wagga (2650) and if so how much?
oh and you don't happen to have an undamaged fan shroud to go along with that do you?
Thanks
-Vince
Hey fatz,
Thanks
-Vince
send us a pm will have to get a quote for the rad
dont have the shroud ( hard to fin not rooted)
Hey mate do you have a good Rb26 clutch fan hub? How much posted to Brisbane 4178
certainly do $50 bux posted
Wrecking Gunmetal Grey coloured R32 Gtr.
Heaps of parts, first in with the cash wins it.....
Rb26dett complete motor $2,500
Removed from a running 32 Gtr in Japan, driven by the buyer before wrecking.
Includes intake, exhaust, turbos, covers etc.
Doesn't include loom or ECU.
Stock ECU $150
Blitz dual stage boost controller kit $250
Speco tacho $60
Gearbox $500 incl shifter. Gearbox crossmember $50
Front mount intercooler (stock) $200
Stock radiator $150
G sensor $450 (not red)
Tailshaft $150
Stock clutch in very good condition $200
Driveshafts: sold
Diff $500
Rear cradle (bare) $100
Hubs $100 per hub, front includes uprights
Front lower control arms $80 pair
Front cradle (bare) $100
Front and rear sway bars $80 each
Front steering rack $150
Rear steering rack (incl rack ends) $150
Front calipers and rotors $250
Rear brakes- sold
Brake master $100 and booster $100
Exhaust manifolds $40
Dump pipes $40
Front pipe (stock) $100
Stock exhaust in excellent condition, includes heat shields (some of which look near new) and cat $450
Carbon canister $30
A/c compressor $100
Radiator overflow tank and washer bottles $20 each
Throttle cable $80
Bonnet release cable $50
Bonnet, grille and front guards: sold
Headlights $250
Bonnet liner/heat shield $30
Boot with Gtr wing and badge $250
Rear bar $100 (mounting brackets are a bit rusty)
Rear bar reo $200
Front window glass $200
Rear window glass $150
Quarter glass $50 a side but it has no seals
Doors $150 each
Side mirrors $30 each or $50 pair
Corner indicator, passenger side- has a hole in it $20
Tail lights $50 each
Front seats in good condition $500
Rear seats $150
Stock steering wheel (some wear) $150
Brand new Jap brand boss kit in box $30
Steering column (plastics, ignition barrel and indicator not included) $50
Indicator stalk $20
Steering wheel plastics $40
Speedo cluster $100
Triple gauge cluster $50
Climate control unit $30
Working clock $60
Interior carpet $70
Unbroken console surround $50
$10 bin:
-Footrest
-Interior roof light- centre
-Interior front map light
-Kick panels ($10 each)
-Boot plastic trim (bit around the lock striker)
-Door sill plastics (bit with Skyline written on it) ($10 each)
-Maroon passenger door handle
-White drivers door handle
-Various seat parts 10 bux a piece
There are stacks of other parts and trims I haven't yet listed, just ask. I'll be updating and adding new stuff as I get to taking photos and sorting it so check the last few posts for current lists of what's left and what's sold.
Pick up Valley Heights Sydney or happy to post most things, but not all.
Pete
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
