Max Amps Pulled From Battery / Cable Gauge Required To Relocate Battery To Boot
I searched for a DIY guide on relocating the battery to the boot, and surprisingly couldn't find anything!
Can anyone advise on the minimum cable gauge required to relocate the battery to the boot? I have a heap of 8AWG cable (61Amp capable) which I realise is probably not going to be sufficient, but I am just wondering if I run 2 of the lines if it will be enough?
Cheers :cheers:
Justin
depending on the quality of the cable i recommend 2awg as a minimum preferably larger,
i measure a starter on a v6 commodore 160amps on cranking. which has lower compression so i assume less work would be needed to crank.
Cheer's for the responses :no: Looks like even 2 x my 8AWG wire is not going to cut it!!!
I think I will leave the battery relocation for another time.
2ga is more than plenty, it is also the same as the -ve line from a mig welder. Hit up BOC gas and just buy some welding cables, works out cheaper than 2ga audio cable :)
My Gtr had the battery relocated to boot, used 2gauge cable, never have a problem with voltage drop or any other electrical problems (apparently these cars are voltage sensitive)
6 Cyl Starter motors usually draw between 200-400 amps. No amplifier wire is going to cut it. You need minimum 2 gauge battery/starter cable. It's about $10/m at repco from memory
welding cable works out a tad cheaper if you have a trade account :)
Also don't forget your starter motor will draw more current in winter and also when the battery is lower in voltage. You need to account for these factors so you don't catch things on fire. Safety first :)
I used 0 gauge audio cable. And I ran both earth and positive. I didn't want to earth though the body. U can't go wrong with over earthing.
Cost alil bit, but I hate wiring probs so I just over killed it so there won't b issues.
  • 4 weeks later...
What are people using for distribution blocks once they have relocated the battery? Having a bit of a look at options for such things at the moment.
stereo components really.. you just need a good ANL fuse & holder that that's it.. don't waste your time with anything else :)
Custom made...
Neutral bar with stand offs in a jiffy box.
    • Robertson was a Canadian inventor, and it absolutely reigns supreme here. 95% of our screws are Roberston. It's literally the only option you can buy off store shelves. What would it have lost out too? I believe it's also very popular in the US.  My reference to imperial was pointed to both NPT and BSP.
    • No. BSP lost to the cultural/technical imperialism of living next to Trumpistan. Face it, Robertson screws were better and still pretty much lost out to the yank stuff. The Europeans hate the Brits and they don't use NPT. NPT is just as "imperial" as BSP is, being based on those useless inch thingos. Just done differently.
    • I live in Quebec. Our license plate slogan is "Je me souviens" Translated is "We will remember" as a reminder to when England conquered us and that we must never forget what they did. Long story short, BSP is unheard of here due to being an English design. I'm surprised our nazi anti english government office the OQLF hasn't kicked in my door yet just talking about it, yet alone imperial anything.
    • Thanks for that! I did a quick Google search looked up some of hydaulic stores and didn't see it listed on the website, I'll give them a ring. Also found out later that I can buy 2 oem bleeder bolts for 10 bux and come with the washer which I might do so I don't waste the money it costs in petrol to find 2 washers (already did that lol). The old copper washes look in good nick, I drove it after taking it off and putting it back on and didn't see any  Part number here for reference if anyone needs: 14053-42L0A
