Hey guys, I'm thinking about welding on a Greddy/Trust sump extension while the engine is out of my car.
Has anyone done one and have any feedback on it?
Does it make engine refit a prick? Was it difficult to get it to lined up for welding?
Any feedback would be awesome. Very little info on here or the web.
Cheers,
Ewan.
Not too sure about the trust one but I had a Hi-Octane one welded onto my 26 sump and it doesnt have any clearance issues at all. I'm fairly sure the trust one would be the same but you should get someone who knows what their doing to fit it just to make sure it's in the right place.
Seems pretty cheap to me. $425 delivered.
Unless you just got a fabricator to make one and hope it works you're looking at well over $1000 change over for any of the recognised guys to do one (Hi Octane, Mercury, etc).
I'd do the cutting and just get it tigged somewhere that specialises in ali welding. Should only add $200 max extra.
are you doing the welding yourself???
if not, factor in that a welder will charge around $80/h plus cleaning and prep costs, materials for welding
alot of people including myself use the micks metal craft or hi octane extensions, they are a realy nice bit of gear
This is a good point, it'll need baking to remove oils etc from the metal and dont attempt to cut it up unless you know exactly what penetration gaps/prepping it'll need as you may very well make it harder to do. That price aint bad for that. Expect to pay 150 for ordinary job, 250 for baking prepping and welding.. Over 300 and they're having you
I went through the hassle of this not long ago if ur running a high vol oil pump eg tomei, the trust ext is shit you will be best off paying Racepace $1500 for their 9ltr sump includes extended pickup and fittings for drain/ breathers
If standard the trust extension is prolly an upgrade but waist of time in my eyes
Yep I brought one. Never fitted it, they don't hold that much more oil. And they hang down heaps low. I ended up getting a race pace sump. Haven't fitted it yet, but fark they a work of art
Hey guys, thanks for the info.
Uwissh- Not trying to be a smartarse but my post above yours is pretty clear about the welding. If I do end up doing it, I'll see how my alloy tigging skills are and I might make an additional side section to replace the baffled bit on the side on the std sump. I'll make it then get it welded on by a pro. I bought the alloy to do for all of $5 from the scrap metal joint the other day. It's 4mm thick so should be strong enough.
Where do you stop money wise??? That's always a consideration. I intend to track the car once I eventually get it back together but it might be 2, maybe 3 times a year max. I know it only takes one gut full of air to kill the whole engine but it's risk versus expense i guess!
I'm a poor man playing in a rich mans game.....
Ive heard with the trust sump sextension and a car that is a little lowered will hit into the apex on corners around the track. Id go with a racepace or high octane coz its a flat pan design
my bad, didnt read that part,
unless your really good at alluminium tig welding or tig welding in general i wouldnt even try to attempt it yourself, has to be done spot on, able to with stand pressure and also be pressure tested to ensure your not going to have any leaks.
as nismoid said, if you intend on tracking it then y would u do a half assed job, get it done correct 1st time n have some peace of mind
I would give it a go, im not the worlds best tigger, but i did mine out of 6mm, with 12mm plate for the sump plug area, just make sure you bolt it to a block when you tack it and outside weld it, then remove and inside weld it.
Edited by Adriano
I'm pritty sure, you gotta heat the sump up super hot before you start the welding. Just get a workshop to weld it. You want it done right, can u imagine doing it yourself and its not done right, pulling the motor out, fitting it, and than putting the motor back in only to find it leaks, or cracks on your first launch. The sump has a fark load of force going though it, if its not done right, you will break weaken it. Also make sure it's bolted down to somthing flat and left there to cold right down, so it don't twist or do anything crazy.
Someone has said (tuner or engine builder) that they've dealt with some dodgy "custom" RB oil sumps that have lunched acouple engines due to poor design. I assumed it was the Hi-Octane ones?
we made our own winged ext. like the Hi-octane ones, out of 4mm plate and made a swing gate baffle and ext pick up. had it welded on by a pro, no baking, etc, just a good tig welder. never had any issues.. its definately doable if your a half decent welder, just leak test it with the special dye ( forget what its called, but really thin stuff that shows the finest seep ) also we didn't take the diff out and no probs.
My current car has the Trust ext. and it does sit a bit low, low enough that I've worn off the bottom edge of the sump plug, and it doesn't hold much more than standard, but it has seen plenty of track and works.
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
