No, they all vary slightly... But it makes very little difference to your tune.
If you tune on the leaner fuel (United) it will run fine on any e85. (Caltex, Powerplus, Drum e85.)
I have been running various e85 fuels over the last 4-5 years with 20 or more tunes, some very lean, some rich. I had quite a few issues during that time that should have blown my engine, like wastegate lines popping off (running over 50psi) and fuel reg/map sensor hoses leaking vac, leaning the tune out to 20:1 on cruise. It still ran fine, no melted pistons or det.
It really is the ultimate fuel for turbo cars, no matter what pump it comes from.
Thanks for the reply. The reason I ask your opinion is that out of the three tuners I have spoken with, two of them have been adament about using either an eflex sensor as Caltex and United's ethanol content can wildly vary, or sourcing from a racing supplier to ensure the ethanol content remains consistent.
So basically what your saying is that regardless of variations of ethanol content, one tune on United e85 is enough to cover the variation in ethanol based pump fuel, and the variation in ethanol content won't damage my engine regardless?
EDIT: This is for a track car only if that makes any difference. Also don't plan to be running huge amount of boost either.
Its true that the ethanol content can vary a fair bit but if the tune is safe on the highest content of ethanol eg united stuff can go up to e90 anything thats got more petrol in it eg e70 etc your car will only run richer which wont hurt your engine anyways. Mate speak to Yavuz at unigroup engineering give him your car and never worry about ethanol content or any of the other rubbish these other "tuners" have been feeding you ;)
Hes tuned both my cars both drive amazing have great fuel economy and have NEVER died :)
Had my car tuned on united over 4 years ago and I have never had a drama with it.
My tuner has tuned literally hundreds of cars on e85, a lot of cars making 1000+hp and united is always the fuel of choice.
Exactly. The only reason you would need an ethanol content sensor is if you plan to run petrol one day and e85 the next, without draining the tank.
A 10% ethanol variation is only a 2% fuel variation, and perhaps 1/2 an AFR point. As long as it goes richer not leaner there will be no issue at the track or on the road. Sourcing race fuel in drums will only help lighten your wallet.
Why won't you be running much boost? My stock VQ loves track days at 30psi... :)
  • Like 1
Who in sydney is famous for tuning on E85? I'd like to hear some feedback from the people. How does Nistune go for E85?
I have to upgrade my fuel system before I get tuned regardless which fuel I run so E85 is looking good. Also the United at Dee Why sells it and I have an empty 200L drum in the garage
Most of the tuners do it now, jem have a good reputation on it or if you happy to go north a little dvsjez has some great results and will go the extra mile to make sure it's right
  • 3 weeks later...
Why would you stick another ethanol pump right near the other stations? The map shows they are all stacked into the same area of Sydney...
Save on transport costs maybe.... Lol. Clowns!
I mentioned to SK when the new "Yagoona" United servo got E85 and he reckoned that a while back when the price of all fuels was really high in Sydney the dough was going into new tanks that are ethanol compatible .
I agree it's easy enough to tune for E70-E85 and the only disadvantage is you'd use more fuel with the higher petrol contend mix . If you were tuned to run exclusively E70 and the light load and cruise mixtures were set for economical running it's real easy to bump E85 up to E70 . Assuming they are 15% different that's a whole 8.25 litres of petrol in a 55L tank so if you were dry adding that then filling with E85 is no drama . Close enough to 2L per 1/4 tank .
I was reading recently that late flex fuel cars don't use these sensors and if that's the case they must have really sophisticated oxygen sensing and knock sensor systems and the ability to self learn really fast .
A .
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
