Looks really nice Robbie. I see that you have fallen in love with wrinkle paint ;)
Cheers, got to see it on Monday and it's coming together very nicely! Getting very closing to going to back in...start of July is booked in for 2 days of front end assembly and motor install :yes:
I think with the turbo you're running, you'd probably end up putting the 600cc in. Seriously no point with the 444 as mine are slightly lesser than 90% duty on 250awkw.
Yep, I am curious just to see how it does go on the stock injectors, AFM's and ECU...once that is know and she is running smoothly the plan is to swap in the Nismo 600cc's, Z32 AFM's and the Nistune
I have to agree with Brandon. Your not going to miss anything with having the the 600cc. Even after changing mine from stock to 550cc I was on 75-80% duty with only 300rwrkw. Theses cars are thirsty but can be fuel efficient if tuned properly and if you drive it sensibly.
Thanks for the info, appreciate it Anthony. What boost level were you running to achieve that?
This is a crazy build mate gotta love the attention to detail.
You going to keep her original colour or are you going something different??
Cheers! I have to admit I have problem but hopefully that results in a R I can be proud of...
Yep, just going back to the original metallic gun metal
Robbie are you gonna put some deadner as well or just leave as is?
Pros and cons of deadner
Pros - extra protection and durability from rust and corrosion and reduces road noise
Cons - its a bitch to apply and takes forever to dry and adds weight to the car
OMFG. Would you please restore mine? I'm in Brisbane too if that make things easier :woot::3some:
Haha no worries man....first ask yourself...'how deep are my pockets?'
Yeah that is deadener man, just took photos straight after it was done! Should look more textured once fully dry....will get more photos
That looks awesome mate!
beste regards from Germany!
Cheers Kev, I really can not believe the amount of prep work to get it ready! I spent a lot of hours underneath it looking up....
This is such a fascinating look at how these cars fit together. They're amazingly complicated cars, the GT-R's. It's also a little sad for those of us who haven't gone to this level of restoration (without the know-how or the money) to see the ravages of time on a car that we grew up loving.
Keep it coming, I'm loving this thread.
-Nick
Stonegaurd going on this week to seal up the deadener/rust protectant
-Nick
Well said Nick. It's a great thing to learn all about the way the R works and fits together. As you said, quite a lot going on under the hood/body!
Bit more progress, all bushes out
Ready to send away for Hydrablast
More prep/painting
Box getting acid washed
Ready for a hit of clear coat
New front wheel bearings
Keen to see what hubs will look like Hydrablasted. Have a pair here I wanna run on my car and would love to have em looking fresh & new and then clearcoated to maintain that look. How much roughly is the hydrablast for just the rears?
May have already been posted, but I'd be keen to know what kind of primer/paint you're using. What kind of durability of the paint are you expecting in the long term (esp on suspension and under body components)? I'd hate to go through all that to see it chip off after a few hundred kays... Sweet build though!
Hubs are back Michael but haven't seen them yet, will get photos up asap for you. Yeah they were atrocious when we started, will get new bushes back in and then a hit of clear to seal them up!
Cost was $180 for all 4 man
That looks awesome mate! We make this procedure current also on a full caged R32 GTR VSpec. Now I know only too well what lies behind it for a working!
Best regards,
Kevin
Cheers Kevin, insane amount of work ahead...I don't envy you!!! Hope you will be putting a build thread up on here..?
hey mate what did you use for underbody and what prep was involved? are you coating the subframe and bits in the same stuff?
First started with truck wash and heavy duty nylon bristle scrubbing brush/sponge (this was hell, shoulders on fire!), then got stuck in with a steam cleaner to really loosen up the dirt/grime, while all still wet got the high pressure washer and went crazy!
Let it all dry out for a week, then went over every inch with the LED work light to locate every inch of rust (was pretty happy that there was fk all), treated any minor bits I found (you would of seen the black painted bits and pieces in previous photos) and then taped up every bolt/thread etc
Next step was the coat of the black under body rust protectant/sealer/deadener. You just buy in a 4L and apply with a specific gun that hooks up to compressed air line.
Let it all dry out for a couple of weeks and the last step is the stonechip protector/deadener, again this is applied by gun/compressed air and GOES EVERYWHERE!!! So not easy to do unless you have the space...
Photos below of the first coat (which was 3 x 1L bottles) of the stonechip
Wow.. That is all.
Just spend the past couple hours devouring this thread I wish there was more to read. I can not believe the attention to detail, I NEED to see this car when its finished.
You've destroyed my perception of a "clean GTR", good luck with the rest of build.
Good old sockets make the best punches on the Hyd Press, keep up the good work. ;)
You know it Benny! Had to whip out the oxy as well as they would not budge without it...once heat in the they popped out easy
Thanks mate, getting frustrated now as keep finding little things to do they prevent me from starting to get things back together...just NEVER enough time :angry:
Wow.. That is all.
Haha much appreciated mate, doing my best to keep the photos coming! I know, I have a problem, just hoping it all comes together as I have planned...Where in Aus are you?
Still learning a lot about the car and loving it more every step closer it gets to being finished. Thanks, still so much to do with such little time to do it in
    • Learned a bit @PranK To add a twist to this take, I've done some further investigation and turns out I don't know if I even have coilovers. I have Mugen Showa on all corners, which appear to be struts / springs online. Someone may be able to correct me if I'm wrong.
    • Well, i've been told it's going to be in Poland around october - november. It should set off by the end of this month. Waiting for it to arrive is the easy part, searching for the right car, wake up in the middle of the night to see the photos and decide whether to bid or not - that was difficult
    • Thanks mate, i'll keep that in mind. Not sure though if the black carpet will fit grey interior. I'd prefer original Stagea set but if i fail to find one in another few weeks, i will probably come back to you. p.s. - is this original, licensed Nismo product?
    • I'm a strong believer that old sports cars should be reserved as weekend cars and owned by mechanically inclined people. The risk-reward ratio is only acceptable under those conditions.
    • @Stringycheese hopefully this is helpful. 🤣
