Hi,
I've been eyeing this forum as guest for a while.
Until I stumbled upon your build in this thread, I am gaining a LOT of information, and made me register to SAU especially to say congratulations on your build. It is really high class and indeed a must-see for all GTR owners.
Cheers and keep them coming.
Regards,
omDidit
  • Like 1
  • 3 months later...
Lakeside Classic - July 26, 2015
None of this build would of been possible without the man sitting next to me. Endless hours spent together talking, planning, working.
Forever thankful Dad.
  • Like 10
  • 1 month later...
  • 4 weeks later...
that sound is so clean, such a smooth note, this 32 redefines what a super car really should be, not a ridiculously expensive prima donna, but more a true almost indestructible super hero, clark kent when your doing the shopping and superman when you need to move faster then a speeding locomotive
  • Like 1
:woot::woot::D:D:D LOL mate this is so good!!! You have a big one last night....?
Always appreciate randomness like this, well done Sir, let me know if you're ever in Bris n we'll go for a run in the hills :thumbsup:
  • Like 2
i followed the the build thread from the beginning and was pumped to see a live action vid, the comment came because about a week before a mate bought a euro sports car and we took it for a thrash in the adelaide hills and a check engine light came on and the car started running like a bag of diseased dicks.
prompting me to ridicule him endlessly as once upon a time i owned a 32 GTR but it was nowhere near your work of art, and i remarked how a true supercar should do everything a car does + some of what a supercar can do.
If i am ever in brissy will drop you a line, planning to move to the big QLD within the next 16 months so the burn will probably consist of me trying to keep up with you in my 33 and failing miserably lol
  • 3 months later...
  • 1 month later...
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
