hey guys sent my car to mercury the other day to get a new fuel pump and nistune fitted and dyno tuned and only maid 156rwkw wanting at least 200rwkw any ideas?
car is pretty much stock except for
rb20det
rb25hiflowd turbo 12psi
255lph walbro f pump
fmic
3inch exhaust
pod
nistune ecu
stock injectors
stock afm
have a new 2 core ally rad and fuel pressure reg sitting at home to be fitted.
https://www.sau.com.au/forums/topic/414349-making-200rwkw-on-my-r32-rb20det/
injectors will be a good start, also ..nistune on a stock afm??? where is the Z32
also i have gtr coilpacks cheap to go with the injectors you need
Edited by GH05T
Z32? i think he's a bit off that.. hope you enjoyed the service... i prefer to actually talk to the person working on my car.. what did they have to say about the result?
Edited by SliverS2
didnt really say anything to me was a bit unhappy with it takeing over a week to get my car back but other then that i think they did ok. definatly will be fitting a z32 now thanks for the comments. any body know some not so pricey injectors to fit or for sale?
so you live around brissy?
Id be seriously thinking larger injectors and getting on the Eflex, it should help you alot in getting to 200kw with 18psi wound up..
I highly recommend you see Gavin Woods, cant speak highly enough of his work, your just as important as the guy with the 35GTR there.
You need to wind up the boost, my old hr31 made about 150rwkw on 14psi with a vg30 and exhaust but stock everything else. My 32 made 230+ but was running about 20psi.
I think the limit of stock injectors/afm is about 180rwkw on a rb20, so I would upgrade them first and get a re-tune, I think you will have to run atleast 18psi or so to get 200rwkw.
Edited by eightsixboy
so ive bought a z32 afm and denso 550cc will fit and tune in the next week or 2 and post a dyno. anything positive to say about denso injectors?
Have to change the plug, and when you want more power later you will wish you had of gone with GTR injectors.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
