  • Replies 59
I has found you a car.
http://www.skylinesa...winfield-g-t-r/
I can has a drive? :cheers:
Sounds great. I think i left $900k in the pocket of my other pants...
Question would be - would I make it out of Victoria without a Defect? :P
I reckon Pettett would make a special trip to NSW to sort you out. :thumbsup:
I'm really tempted to do this....it's all on finances.
The cars ready....just needs a road tune, tail shaft and the power steering cooler put back in.
I just hope it rains! Evo-tard hunting for me....might be time to use those rub guards again!
Mr2 hey....
I prefer not to go randomly spearing off into the scenery.... :P
Nah I'm sure they are good, but I'm after a Nissan. I've already started collecting bits!
I look forward to showing you the benefits of inherent balance........I do understand about NIssans though as so many bits are interchangeable, Silvia of some sort? An R33 GTST? GTR if you're really cashed up?
wanna go me homie?
I'll definitely be making the long trip 1 hour down the road to watch all you crazys fly around. Unfortunately I doubt my gearbox would be up to the beating it would take, so I'll be spectating.
Will there be a gate entry charge to spectate?
I can't help with a guide to good accommodation (as I live close enough to not need it), but I may be able to make your choice a bit easier depending on what your plans are while here.
1) If your main focus will be the driving, I'd say get a room in Benalla 5 mins from the track or Wangaratta 10-15mins from the track. This option would also be for you if you didn't want much night life. Also I'm not sure if Benalla has any type of dedicated autoparts store, just a few machanics and car yards. Wangaratta has a supercheap and probably a couple of other options.
2) If however you'd want to be partying a bit harder than just being at a pub, I'd say get a room in either Albury or Wodonga which are both about 1 hour from the track. Albury has a decent night life (if you're into that sort of thing).
Hope that helps some of you.
Although now I've checked the actual date I see it's a Monday. For some reason I assumed it would be a Saturday haha. I would still say the above is true, however Monday night would be quite tame compared to Wednesday, Friday, Saturday or even Sunday nights.
Edited by BMX666
well i dunno about the other guys but i'll probly have 1 or 2 mates with me and might make a weekend of it drive down either sat or sun come back tuesday but depends on price aswell i suppose.
Hey Theo - I'm going to have a crack at your time at Eastern Creek South first. I'm booked for the CAMS come and try day on Jan 19th. What did you end up with? 1:16 or something?
it was a 1:14.77 i think............ Jan 19th that might still be a bit warm LOL luck of the draw i guess.
Yeah, its short sessions as its a come and try day. $30 gets you on the track if you haven't had a CAMS licence in the past.
only 3 flying laps in a session- with an instructor too, but gives me something to aim for :)
Cheers, for the accom tips.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
