Yes Joey, drag slips, its the only way to be sure, I'll race you for beer (no more little bloody donuts, bastards).
You will though need to spot me 5.5 seconds though.
I'm guessing you might run a 10.5ish where I might run a 16ish
Come on, my 5 has at most an astounding 80 to 90 killerwasps at the back wheels.
Put It this way, my old RWD boat on old drag radials and 380kw got a 11.008, I'm sure there's a 10.5 in yours.
The box should be fine for the first couple of runs, it might sound a bit like industrial exhaust fan after that though.
In all honesty if you take off easy and don't shift to hard the box should be fine, I believe its the drag radials and big launches on the sticky stip that eats the 1-3 gears.
Ill give you 4.9 seconds then, with a 6 pack of Crownies on the line.
EDIT: First gear?, with your torque the only time you will use first gear is in the lanes before the water box
Righto,
take this as you will, i consider that engine capacity, cams, fuel makes it a "similar" comparison
So same dyno
Both set ups have
2.6L
both have standard compression from memory
similar drop in cams
high ethenol content fuel
Both have large sufficient exhaust, ignition and fuel setups
Mine is the orange/red line
-5 line is black
To be fair, that -5 result im comparing against wasnt the most responsive run out of them all. But that particular result did flatten out alot after 5200rpm and my curve was still fatter
I dont know if i want to test the waters.. maybe when i get a stronger box.
I would have just got the thing on the road and i dont feel like spending more $$$ to keep driving it haha
Oh yup similar looking results to what I got just bait higher because of the ethanol.
I might stick with the -5's until i upgrade my injectors/gearbox and then go with a 8374 1.05 A/R as my bottom end has been built to withstand hell.
and I hear you about popping the standard box. Why I haven't run mine yet.
It's interesting to note that there is very minimal change in power between E45 and E85 on our boost levels. It's only an extra safety margin..
I'll be running 50/50 as a more common everyday mix
Lol, lies, I see lies :P
You can't really compair single v twin cause to many veriables like intake and dump pipes etc, dump pipes are one of the biggest issues with turbos and it's hard to get wrong on a single, especially if you have a external gate, but very very easy to get wrong on factory mount twins
Even cam timing makes a difference
So it really comes down to personal preference and what you want from your car
Haha, maybe, doubtful but maybe, but twins will get you there quicker :P
Take matty from WA's experience. Twin -5's on a 3.0 and went to a 8374/0.92 internally gate single. The EFR was back to peak boost levels in a 1/3rd of the time the twins took (Motec logs), made more power everywhere also.
However, it would be interesting to compare something like the 8374 EFR to say twin 6258 EFR's.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
