I am looking at joining the M35 family fairly soon, but I am having trouble find afew key details that will help me buy the right one.
My main questions is, without jacking up every car I look at or laying black lines on the pavement, how do I tell it has the LSD option?
So far I know that:
250T RS Four had the option of LSD
250T RX Four didn't have the option of LSD
AR-X comes with LSD
Nissan Fast doesn't actually tell you if the car is fitted with the LSD option.
Can I tell by the diff housing? (If so, photos would be great :) )
I've read that the service manual states that the Turbo is a recommended replacement at 100k Service, is this true?
What boost do each model run standard? I know that the AR-X runs more boost then other models, but I am not sure exactly how much.
Cheers
https://www.sau.com.au/forums/topic/414859-m35-stagea-series-1-questions/
So far I know that:
AR-X comes with LSD
Cheers
Hi there the ar/x runs 14lb stock and the others run 12lb as for lsd not sure, ar/x has them standard.
Has this been proven Rudi? It's simple to drill out the restrictor in the solenoid line a little to bump the boost. I would prefer the non ARX if that is the case...
Don't get the LSD model either, as you will get wobbly wheels with it (Hicas) Just get the non LSD model and buy a 350z LSD later as the ratios are better...
just going by what I have heard , could I put the 350z LSD in mine and do I need to retune etc?
Fast will tell you if the car has been optioned with LSD (or anything else) by clicking on the blue and white OP button up the top of the menu.
When we checked mine; the LSD din't actually appear.
No re-tune required but you would need a matching ratio front diff unless you drop the shaft.
G35x would probably be the cheapest way to do that.
Or if good price from NIssan, PNM35.
May have been added at a later date?
Ok thanks for your help guys.
What is exactly involved in changing to say a 350Z or G35X LSD?
The turbo at 100k as part of Nissan recommended replacement? Assuming that the exhaust wheel is ceramic like most Nissans, it would seem an ARX models running around the 1bar boost would be more akin to going pop sooner.
Well that depends if you want a whole diff, or just going for the parts and re-using your external. Best option is to get a whole pumpkin, and bolt it in. That being said VLSDs do get a bit long in the tooth, so another option would be to just get a quaife to suit a open diff installed.
The other part is a bit more difficult. The front diff needs a fair bit of disassembly to get to and change. This, as has been said, can be obtained from wither a PNM35 front diff, or a G35x from the US.
Basically look for any options for 350zs and you can use them- just be aware the ratio is different.
Its not a cheap exercise. Another option is to buy a ARX VLSD from YAJ or something, if you want to keep the std diff ratio.
Yes turbo is recommended replaced at 100k. Doubt many of them would have been changed. The main factor with the stock turbo is servicing. If a bit of crud blocks the very small oil feed- its game over. The other thing is the std dump pipe is very restrictive. causing higher heat and wear. They can be pushed quite hard with the oil feed drilled out a little, and a high flow dump pipe installed. I believe they are steel wheeled, not ceramic.
Don't worry about ARX vs RS/X regarding the turbo.
If the turbo hasn't been rebuilt just budget for it to be done sometimes in the next 1-2 years of ownership. If it lives longer, happy days, but don't be upset if it blows up.
Sorry to hijack thread but im looking at 20x8.5 rims. What offset should i look for on 01 m35 rx. +35??
how much low?
somewhere around +high teens to +25. +35 sit too far in. Choose enough tyre to not ruin your ride if your going 20s. And please not bob jane specials....
If the turbo pops/is stuffed, then what are the better options (rebuild/exact same replacement /better alternative replacement?)
What sort of man-hours to remove and replace Turbo?
It is probably twenty hours work to complete, including bleeding the coolant and changing the oil. Unfortunately there is a week or two wait between removing and refitting, as you have to wait for Stao (Hypergear) to complete the rebuild. Craig has had quick turnarounds at Precision turbo's in Sydney but they are $4-500 more expensive.
how much low?
22-25 will leave enough roon for a decent not stretched tyre.............................................................................................................................................
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
