Have a chat, post your videos and Pics here!
I've got almost 100 gigs of video to sort through so give me some time folks. I'll try to get a couple of short "teasers" up quickly though.
Huge thanks to the Boys at Unigroup for hosting such a great day for us. As you saw they didn't get a break all day and worked through the heat.
Also thanks to the execs that helped out. Mechanic Sean was on the spot helping people with their shaft and Terry's ice cream fozza van went a treat in the hot afternoon.
https://www.sau.com.au/forums/topic/415240-dyno-day-unigroup-wrap-up-thread/
awesome day guys! didn't get to take many snaps as i wasn't there for long but a few photos trickling onto http://www.facebook....lampoketuckdope make sure to like the page and tag people in the ones that come up! (there will be more popping up throughout the week) :)
as you can see i have a "thing" for Sean's car :P
Very professional jobs done by Yavuz, Mark, Sean & Duncan :yes:
Congrats to all who take care of their cars and didn't have to cause Yavuz 'worry' about possible breakages.
I wanted to try out my Engel fridge to see how long it would take to drain my battery > it nearly did; but not quite...
- but I knew I was in safe hands, so long I wasn't the last one to start up his vehicle to leave Unigroup lol
Fantastic day,nice to catch up with peeps old an new,
but not a lot of ol schoolers left from ten years back.
Still love my 33 do so many ks a year up to 332000 now.
Still feel nothing is better than a jap import. :woot:
Good chatting with everyone including you Chris. I hope you can remember all the names of new acquaintances?
Might see a few of you at the SAU picnic next weekend?
And Kieran, if you're on here, can you make a copy of your insurance company's PDS for me - does your new car have 24U on the block???
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
