Hey guys,
this is a thread to share updates on mods and work you've been doing on your V-Series.
I'll kick it off.
Fitted a BlackVue DR400G-HD2 Camera to my car - living in Melbourne I've had 3 cars vandalised in the past 10 years. Using motion sensors, this camera will record video activity sequences that go on around my car when it's parked. It also records video and audio when you're driving, including speed and exact GPS location - both features which would come very much in hand if you have to file or dispute an insurance claim. Coupled to an alarm and immobiliser, it just helps me sleep at night a little easier :thumbsup:
http://www.autoblackbox.com.au/index.php?route=product/product&product_id=83
84370925_1_644x461_videoregistrator-blackvue-dr400g-hd-ii-versiya-2-16gb-novyy-sankt-peterburg.jpg
That's really cool, great idea.
Well for me, not so much what i've done today but what i am doing on the weekend is an oil change and brake fluid change. Then hopefully in 2-3 weeks time i'll be purchasing my new CD009 gearbox clutch & flywheel and i'm pretty damn excited for that!
This week.
k'n'n drop in's
Removed nissan badge from the boot.
Professional detail and polish removing tar and metal flakes and leather treatment.
Tinting and 4 new goodyear directional 5's
Target now is to get the cart paid of then full stainless invidea exhaust and kinetix cats.
I pumped up my front left Tyre!
Well, not to amazing, however I only knew the front ,left was low because a few weeks ago i "installed" a tyredog remote pressure sensors. I bought it on eBay, and wish I had had it a few months earlier. I lost pressure in my front right, and didn't realise till a few KM's later. Enough to put a big dent in the rim, basically forcing me to get new rims (expensive). If anyone was hesitating about getting this, I would say go-ahead. Its a simple "install", you simply put on these special valve caps put a battery in and your away. It was interesting to see that the Tyredog was showing 27psi and the digital pump at the station also said 27psi.
bought a VLSD out of a 350Z to replace the 3.3 open in my 250GT, having it shimmed and installed maybe get a nismo finned diff housing.. getting a transmission fluid change, engine oil and filter change and having the brakes adjusted.
I replaced my engine oil last night, so difficult when my car is low as f*ck had to drive the car up on bits of wood to fit the jack in..
Still need to change the filter, i didn't end up finishing the change until about 7:30 last night and i was tired as f*ck so i thought i'd do it next oil change.
Is it normal for my car to use 1L of engine oil in about 7,000km?
Yeh , Sean I'd go grab a set of those $100 ramps from Repco, the ones with the lowered car extensions - the standard ones are useless for a lowered car.
Safety first, bro. I have done some stupid sh1t working under cars in the past, and been very lucky a couple of times.
I don't take risks anymore after a friend of mine's husband had his car fall on him in his garage - she didn't find him for a couple of hours - but they are pretty confident he was killed instantly.
I'll add it to the wish list Mat, I had the front of the car on chassis stands so i don't believe it was very risky but i do understand what you are saying. I do get nervous every now and then about that sort of shit happening.
That's horrible to hear, i can't imagine that sight.
But in response to my question before, i have used just over 1L of oil in around 7,000km.. i have heard some of the motors in the states were recalled for bad oil consumption. Is this something to worry about?
Edited by Seano350GT
Because i had a big day yesterday i was buggered, changed the oil and couldn't be bothered f*cking around trying to take the filter off because of it's position and the sump cover in the way so i put it in the too hard basket until probably this weekend.
Nice nuts Mat.
Sean, we give to strife because we can.
I get the car on ramps, take off cover, move tray under sump, remove plug, try to catch plug, remove filter and go have a smoke. That usually does it. :)
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
