$150
and I'm divided
I bet I could go around every ones skyline and spot mods with no benefits other than visual .........
Edit: This one https://www.justjap.com/store/product.php?productid=17670&cat=272&page=3
Sent you a PM
Approval Application:
(1)What is it? Air Pod cover -http://justjap.com/store/product.php?productid=17671&cat=&page=3
(2)Why do you want it? Because CF is not allowed and red is matching the base colour - also to have a bit more "Fill" effect in the bay
(3)How much? $150 + postage
(4)Scale of want/need from 1 - 10 (1 being want and 10 being need): 4
(5)What is product made of? Metal?
(6)did you seek approval previously (if not skip question 7)
(7)What was the result and reasoning? Wanted a CF one but apparently it's to wank factor.
(8)Any risk to damage of car/reputation/ other: No damage - however reputation may drop due to having matching colours
(9)Other: N/A
If you guys could please sign off on this?
Edited by RosieR34
lol... Forget the haters Jeremy!
If you want the box put it in. I'm looking to put one in soon too, car came with pod filter so thinking about this box to make it less appealing to defect police.. Thought about making one, but after spending cash on tools needed and perspex, etc. might just try find a used one. They are on ebay for about $100 also. Not like it has to be high quality =)
  • Like 1
dude i told you dont worry about the pod filter it actully gives 0kw gains if not it just gives you more heat soak. The stock intakes are actually a nailed design. Ive been trying to convince him just to go without the certificate. Its not November yet the worst thing that would happen is that yo have to go again im not sure if you have a number of times that you can try to get cleared. Id be guessing three times.
I believe 0kw is true but is throttle response a little crisp/responsive?
Also is heat soak much of issue......doesn't the air run through the intercooler before the the TB? I know at idle or low speed it will make a difference but not enough to affect a daily driver, surely?
I am a noob at the RBs but I have come from modding a supercharged v6 where a w2a is mainly used and the blower sitting on the intake manifold has a lot of heat soak and it is comonly discussed.
Not trying to be a smart ass just trying to learn a little.
I was also looking at one Jeremy.
Edited by gtr judd
Stock airbox sucks cold air, but has a small intake.
With exrta holes cut its less restrictive.
0$ upgrade that works.
Unboxed pods suck hot air.
No good.
A box can be as cheap as $10-$20.
No good.
Yea I can see how warm air is sucked in with out this box thing mentioned above, but with the pods enclosed surely it isn't that bad?
When at speed, there wouldn't be that much hot air, but standing still etc there would be more soak.
It's interesting 10 minutes after a drive to remove the shield and feel the Pod. Definately cooler than with no shield.
I need to trim my NAP Custom Shield a little after pulling my cooler out for cleaning, everything went back together just a little differently and it currently doesn't fit. :(
  • Like 1
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
