Washed the Pulsar and the 33 after doing a bit of garage rearrange.
Never thought a Pulsar could make a Skyline look small.
I note the 'P' plate on the fridge, is there a meaning in this? :whistling:
BTW .. nice job with the garage mate, cars give a nice mix to your approach to the world.
Edited by THE34T
You make it sound easy but I'm sure it's not.
It wasnt too bad. Hardest part was getting the new cradle in without a diff. Had to balance it on a plate with the jack under it. Took some jiggling to get the pins lined up.
Dropped my two r200s off at diff shop thismorning to get the GTR mech LSD swapped into the s14 housing.
Doing this for more power handling ?
Thats so cool how sht lines up....Jap cars are like lego cars. :yes:
I need to do something about rear traction, i gave it a little squirt and got fully sideways today... not what i want.
Especially on the road with traffic and gutters and things to smash into.
Must try a softer spring setting in the back, and my rear alignment settings might be wrong.
  • Like 1
Does buying it today count? Lolol
Yes! :yes:
My Dad Traded his '94 Navara in on a 2009 SUBARU FORESTER S3 XS Premium Today!
WELL DONE DAD!
Stoked for him. :woot:
  • Like 2
Yep, now I just need the more power bit!
I imagine a torquey 400kw and drag radials would destroy the old driveshafts. GTR rear end should be next to unbreakable. I hope.
I'm going to need an alignment too with adjustable toe and camber just whacked in to get it rolling. Craig Hall should be able to sort it out :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
