Washed the Pulsar and the 33 after doing a bit of garage rearrange.
Never thought a Pulsar could make a Skyline look small.
I note the 'P' plate on the fridge, is there a meaning in this? :whistling:
BTW .. nice job with the garage mate, cars give a nice mix to your approach to the world.
Edited by THE34T
You make it sound easy but I'm sure it's not.
It wasnt too bad. Hardest part was getting the new cradle in without a diff. Had to balance it on a plate with the jack under it. Took some jiggling to get the pins lined up.
Dropped my two r200s off at diff shop thismorning to get the GTR mech LSD swapped into the s14 housing.
Doing this for more power handling ?
Thats so cool how sht lines up....Jap cars are like lego cars. :yes:
I need to do something about rear traction, i gave it a little squirt and got fully sideways today... not what i want.
Especially on the road with traffic and gutters and things to smash into.
Must try a softer spring setting in the back, and my rear alignment settings might be wrong.
  • Like 1
Does buying it today count? Lolol
Yes! :yes:
My Dad Traded his '94 Navara in on a 2009 SUBARU FORESTER S3 XS Premium Today!
WELL DONE DAD!
Stoked for him. :woot:
  • Like 2
Yep, now I just need the more power bit!
I imagine a torquey 400kw and drag radials would destroy the old driveshafts. GTR rear end should be next to unbreakable. I hope.
I'm going to need an alignment too with adjustable toe and camber just whacked in to get it rolling. Craig Hall should be able to sort it out :)
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
