could be the clear coat coming off
sometimes that can make it look like a respray in areas
I think it definitely is in some places.
Though I found some black spray paint on the front passenger window which sparked my thinking.
Haha very wary of crossthreading, all good!
But yes, my delicate hands were not made to work on the GTR. I have 2 small grazes, a bump on my arm and a small chunk of skin missing from my finger but GTR now has fire extinguisher!!
Get yourself a few pairs of these >> http://www.signet.net.au/store/products/40857/ansell-hyflex-11-618-gloves-size-9-12-pairs-per-box
or similar for working on the car, we have to wear gloves at work and I borrowed a few pairs for home. I've gotten so used to working in them I feel like something is missing if start playing with the car without gloves on.
Pulled the Twin Turbo pipe off and the Apexi intake pipes for polishing.
Also getting Sin's old polished plenum re-polished as well.
Only thing I could get off is the rear turbo elbow pipe. May have to paint this black!!
Washed and started polishing the SkyHatch but not finished...
Got involved in much more exciting things like pruning the roses but did a Green Waste run in it. Practical it is.
I'll finish it of tomorrow and Vac.
also got my N13 Haynes Repair Manual today for $20. :D
Started the skyline for the first time in a few days.. It really wasn't happy and was running on 5 cylinders for a few seconds. I'm guessing it will only get worse if I leave it for longer periods..? Any recommendations?
Might check the plugs when I get a chance, it's almost been 10k.
Edited by dontyellpl0x
I don't have any problems starting the GTR after longer periods besides battery (problem solved leaving trickle charger on it).
I also don't remember the last time I got 10k out of a set of plugs! :)
You mean like tuning it up to the edge and drag racing? :yes: Yeah, that will give the plugs a hammering.
Sold VC commodore today for a small profit :yes:
Not an easy thing to do these days. Nice one.
Gave mine a quick wash, its losing gloss in some areas, maybe its just the wax, but it will get another polish soon anyway.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
