Quick update.
Received this today
Mines Triple Flow Cam Cover Baffle Plates
Comes with sponges (to clean my dirty windows lol :P )
and the necessary instructions all in Japanese not that it takes a rocket scientist to work out how to install them.
Great work.
I run the Nismo dump pipes (as seen above) and the 90mm Midori Ti front pipes and love the set up.
The combo you have gone for with the Mines dumps and 80mm Midori Ti front pipes will be really nice.
Thanks guys.
Those nismo r-tune coil-overs look sweet and are listed cheaply. But then again its is an auction and I'm not sure if they are totally new???
I'm actually looking at getting these for the car, but not certain if they are going to be too harsh :blink:
Would be interesting to know the spec on the BC's? Spring rates etc?
I am running Tein Monoflex and they are definitely to stiff for street / hard street (i.e. hill runs).
When coming in hot to sharp bends it is challenging unless the surface is smooth as the car bounces around too much, causing ABS to come on and understeer to occur.
R-tunes are basically ohlins flag-r's. So after market springs etc are cheap from 'Swift springs' if need be.
Brand new retail is close to 6k a set delivered.
If need be I can arrange bidding, shipping and new springs.
Thanks guys.
Front Spring rates are rated at 10kg
Rears rated at 8kg
Thanks mate, I am keeping all options available FTM, so will let you know in case I go down that path.
Rears rated at 8kg
Forgot to mention this
C ER Series Coilover Standard Features:
- Front External Reservoir
- Front Pillowball Top Mount
- Rear External Reservoir
- Rear Pillowball Top Mount
- Twin Piston Design
- Separate Compression & Rebound Adjustment
- 30 Level Damping Force Adjustment
- Full-Length Height Adjustment
- Anodized Alloy Casing
- CNC Machined
- T6061 Alloy Locking Ring
- Monotube Design For Maximum Performance
- Fully Rebuildable
- 12 Month Warranty
Ants, have you considered the German KW Suspension?
http://www.kw-suspensions.eu/int/kw_variant_3.php
Not sure on pricing, but plenty of top level motorsports teams use them, and have seen plenty used on the Hillclimb stuff too. Something that I'll be looking at when my current RG coilovers fail (which they're beginning to do) in my Silvia.
So lately I have been focusing on the cosmetics of the car which I must admit is pretty shifty :unsure: as I actually put the bodykit myslef many years ago whithout really knowing how :whistling:
So firstly the LHS sideskirt needed to be put back on which looked like this
Its a one peice fibre glass copy of the N1 sideskirts which are actually pretty nice (if fitted correctly)
I off course I gave them a good clean first, then trial fitted them to ensure that I did not have to mak any adjustments to the sideskirt which is a critical step to undertake if you want the bodykit to fit perfectly
Now the fun bit :yes:
I applied some Sikaflex 227 adhesive on the side skirt using this. It is important to have a good gun and this actually was quiet exy but worth while (notice to nozel saver, is good to have if you don't want the adhesive to dry out on you)
Then the not so fun bit....
To ensure that sideskirt sits absolutely flush I had to secure with clamps but trying to find a spot to clamp where the rear seats and the N1 skirt lies was really hard but I managed.
Here you can see that there are no gaps between the sideskirt and the main body of the car
After a couple of hours once the adhesive has hardened I took clamps off and here we go.
here you can see how well the side skirt fits and sits perfectly
I will need to do the right hand side but will most likely to do after the car has been tuned
Now I also wanted to fix up the rear pods and I started with rear RHS pod which used to look like this
you can see that it does not sit flush against the body of the car so I am going to correct it (something that has been bugging me for a loooooooooooong time)
so I started to remove it, there are two bolts in front of the rear spatters and one underneath (which I did not have)
here you can see the excessive adhesive and crap that has been applied causing the pod to stand out
Then get a scraper (preferably a plastic one) and remove the old adhesive material
picture after removing adhesive bits and after a little clean. There is still some glue (supa glue believe it or not which is impossible to take off without chipping some paint :verymad: )
so the next step was to sand it with some 1200 grit wet and dry sandpaper to get like this
Then prep time! to make sure that no paint gets spattered where it is not suppose to
I used this instead of the usual White Knight primer I have been using, which has a superior rust protection rating
Photo after first coat applied...some of the paint was sagging so I waited for it to dry and sanded it with 1200 grit wet and dry sand paper
Finally, resprayed it with some holts auto spray (DSSB01) to get like this.
Not quiet finished with it and will re-sand it (very lightly) and then apply a coat of Motospray Topcoat clear to make it nice and glossy (not that any is really going to see as I will be putting on the pod after I restore it :rolleyes: )
Now for the pod
was full of crap inside it
gave it a good clean and removed the adhesive that was on there (prep wash gets rid of the adhesive very quickly)
Here you can see how the pod has been battered by gravel, sand etc.. from the rear wheel
Photo after been sanded
used some p80 grit and then p1200 (fine) grit
Next time I will get them resprayed and refit them but that is all for now :action-smiley-069:
Edited by Ants
Hey ants great build so far, love reading it. Just thought ill mention that I bought the bc er coilovers your thinking of getting for my gtt a couple years ago and i found them to be too stiff on the street but very good on the track. I didnt notice any difference when i adjusted the settings either.
Ok I know that its late and passed my bedtime (for old me ;) ) but I thought I would share this with you all:
This arrived today :banana:
It is the missing puzzle to the exhaust system
Tomei expreme Ti 3.5inch cat back exhaust
always nicely packaged
almost speechless at the beauty of this muffler
Gonna be LOUD!
There is just something sexy about titanium :teehee:
comes with the necessary bits of gear to piece it all together
I actually like this....a nice cool Tomei badge I can put on the car (most likely beneath the rear RHS twin round taillights)
last but not least.....
Nismo titanium GT shift knob (I already have the normal polyurethane nismo GT shift knob but thought what the hell)
have good night
Edited by Ants
Thanks for the feedback mate.
I have still have not decided what coilovers I want, but I have an idea.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
