Hey Ants! I just read through your build thread... i was bored at work today :)
Loving your attention to detail, I wish i had the time (and $$) to put as much into my GTR. Maybe when I retire mine as my daily.
I'm glad you've soldiered on looking forward to seeing the end result of all your work!
thanks mate its always appreciated to hear that (things you do when your bored :teehee: )
its a bit of a roller-coaster ride FTM and I am trying to deal with it the best I possibly can.
Really enjoyable build bud, Will be checking for more updates!
Thanks buddy. I endeavour to have some nice updates coming very soon :yes:
Edited by Ants
few pics while I was at workshop
Garrett -5s bolted into place with HKS actuators set to 15psi each (my beautiful daughter in the backgrounds :) )
Mines dumps pipe - sexy bit of gear
braided turbo oil and water lines fitted
here you can see the new silicon hoses fitted (pushed aside FTM)
Will have some more exciting updates coming very soon, so watch this space ;)
Awesome build mate loving the little 1%'s like match porting etc. it makes a lot of difference in the end when you've put so much of your own hand time in. Even tho it may not be quite as good as what a pro shop might have done, if you can do a good job yourself I think that's always better. I bought a tig welder and did my own fab work. Didn't really save myself much but it didn't leave the garage and had some fun at the same time. Any muggins can pay someone else. Not so sure about spray can painting lol I'm a ex panel beater and was lucky enough to do my time with a prestige shop, so not so big on spray can jobs lol. But credit to you the bits you've done look quite good. It's coming together great, going to be a very very nice car that engine is a ticket item to making it a stand out. Special Japan magic. Putty I'm a thousand or so Kay's away otherwise I could of sorted that few little rusty patches for you. I'd say she's seen a little bit of salt in the northern parts of Japan. Not as bad as a lot of them tho. I wouldn't be too worried about what you uncovered, minor. Keep it up mate.
Edited by Mr. Untouchable
Thanks for the positive comments mate. Yeah, although they may not make a massive difference performance wise, all the small things make a big difference to me. Seeing the results from doing the work myself is satisfying and considering I work in an office 5 days a week and that any mechanical or detailing work is not my profession makes it even more satisfying. What I also like about doing things on my own is that I get to learn (from mistakes as well :whistling: ) and I'm quiet nicky picky with things so can only blame myself for not doing it correctly ;)
The rust is an issue and even after I have the engine installed and I have more work to do on it and will keep this build / restoration thread alive for a bit longer.
awesome build mate, really looks the goods. that tomei crate motor is the goods too, cant wait to see this thing in the track. good luck with it, and stick to your guns, it will all be worth it at the end ;)
Thanks Dale. The Tomei engine is really my dream coming true and even I cant wait to see how it goes. Will certainly be sticking to my guns but I am also happy to listen to others which is what makes this forum so special :yes:
I have decided to go another way with the ECU and received this today.
Haltech Platinum Pro Plug In ECU - hopefully it can back up its great reputation. If not I still have a Apexi PFC that I know will deliver results.
are you going to ceramic coat the dump pipes?
No that would be a crime :P . Besides, now they are bolted up I'm not gonna bother, although I know it would assist keep heat in the exhaust rather than the engine bay.
Good choice on the Haltech, I too am thinking of going down this path.
Do you plan on retaining the AFMs? The thing that put me off the Link is that apparently it will not allow me to run the AFMs.
Yeah. I had been talking to a few guys on SAU (namely Qld members ;) ) and really educated me on ECU choices. One of the key reasons why I've gone Hatlech is to do away the A/F meters.
The other reason is that it has more tuning capabilities than an Apexi Power FC which is good to have for track days.
Awesome build thread man, Can't wait to see the
final result.
All the best.
thanks mate.
Oh, so that's the one you bought. I thought it was new.
Great deal that one!
yes, that's the one ;)
  • 3 weeks later...
Apologies for the delay everyone.
Engine is now finally bolted into the car :)
Just need to attach a few more ancillaries including exhaust, fluids, then run-in tune. then after that she will be back with me :banana:
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
