I've been told that all cars, in particular Japanese cars, overestimate your speed, so that the speed shown on your speedometer is actually off by a bit. I tested mine using a phone app called Ulysses Speedometer which uses GPS tracking to measure your speed exactly. I discovered that my speedometer is off by a ridiculously huge 8.3%. Which means when my speedo reads 100, I am actually only driving 91.7. And that to reach 110kmph which is the top speed on some highways, my speedo actually has to read 120kmph. I dislike having to estimate the speed I am driving at and never quite sure if I am now speeding or not, and am annoyed that I must be the frustrating person on the road driving unecessarily under the limit.
Have you guys measured the difference on your car? Is it similar to mine? Can it be adjusted?
Edited by puddlejumper
my old car had speed on the turbo timer which was usually about 2 kph less than the speedo at about 100km. the timer was calibrated at 60kph from the speedo though...
Comparing speedo to satnav in other cars usually had about 2-3k difference also (but they weren't jap)
So i think usually a speedo is only a cpl k over actual speed.. things such as tire size and wear can have an affect on the precise accuracy...
As per above, unless you are running the stock tyre sizes (which almost no-one ever does - even on stockies), then you will affect your speedo's accuracy. My tyre width/profile is WAY off - my speedo is out by about 15%, but I compensate for it and normally use my GPS digital speedo instead of the oem cluster.
You will find all the V35's and M35 Stageas have this discrepancy, but the ecu gets a good speed signal and you can display this actual speed via the obd2 port. (it is much more accurate.)
I agree, it is very annoying and can cause frustration, 10k's out at 100 is a joke.
My V35 is fairly close. About 2% last time I checked with GPS. And I am running stock size tyres.
But our J31 maxima is out by about 8%. Again with stock size tyres.
My V35 Coupe seems to almost spot on - I've tested at 80 & 110 against the GPS in my phone, and the difference is no more than 1 - 2 kph. I've got 18s with stock rear tyres - 245/45R18.
I got 2km/h difference between the fronts and rears because of the tire sizes (width and profile) that came with the wheels, I'm not sure how much it is in relation to the speedometer. Use this tire size calculator (http://www.1010tires...ecalculator.asp) to help you choose the tires within the closest possible tolerances for your set of wheels. There may be other factors as well...
Edited by 81gSKy
Here's the results of a test I did a while ago. As per above, the Informeter (display from OBD2 data) is accurate, thus confirming Nissan deliberately engineered our cars to show the incorrect speed on the dash.
So, are we saying that the GPS is connected to the engine control (ie fuel)? and the traction control as well? What happens when the GPS loses a signal?
?? GPS is only used for Navi. If you don't have Navi, your car doesn't even have a GPS receiver. the ECU uses wheel speed sensors to determine vehicle speed (as well as using them for ABS, TC and VDC). If you are running stock size tyres, the ECU speed derived from these sensors is quite accurite.. however, the speedo doesn't display exactly what the ECU reads, the speedo almost always reads faster.
If you look at the graph above you will see it isn't 10% across the board.
I corrected the speedo on my J30 years ago, there was an adjustment on the back of the speedo cluster which adjusted a % of speed, however, the speedo was also out by an absolute figure, there was no adjustment for this, but fortunatly I was able to elongate the mounting holes where the speedo mechanism attached to the face, that allowed me to make an absolute adjustment and I was able to get the speedo to read accurite at 60, 80 and 100km/h.
I had a look at the back of the speedo cluster on the J31 Maxima, but there is no physical adjustment.
at least puddles speedo is out in the negative direction. years ago i found out the hard way that my car was showing 100 on the speedo but was actually doing 111 on the road... *flash*
You should've been able to contest that... Right?
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
