FYI my brother-in-law David (Red back on SAU) is running his R33GTR (with R34GTR Nur engine in it) at the Bathurst Motorsport Festival this weekend. FB group below if anyone want to check out pics/join.
https://www.facebook.com/groups/586460034705368/
The 33 with the impact damage? :( God that looks like it was a massive hit...
-D
Yeah he hit some oil and fishtailed it into the wall :( They are on their way home now - car is not a write-off (we assume), but there is a substantial amount of damage :(
Yeah sadly it was looking the best it has ever looked - I had never seen it so clean and it had never run the Enkei rims on it before either (as the inner plastic guards needed to be modified so they didn't rub).
The front looks bad, but thats only because the guards are alloy and fold up like tissue paper. I had pretty much the same wheel angle after I hit something, I bent my rear subframe, but they arent overly expensive things. The bodywork will be the killer, and if he wants to get the airbags working properly again...
I spoke with David this arvo - looks like a reshell needed - so we are on the lookout for an R33GTR rolling shell. Ripples under the passenger floor, engine/gearbox mounts damaged .... looks moderately major. Sure it will be fixable, but it is a matter of figuring out whether it is more economical to re-shell it or fix it. Plus David is a bit of a perfectionist, so I am sure he would not be happy with fixing the old car if a new one can be had for a reasonable price.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
