I am throwing out a westinghouse dishwasher on Monday morning. Perfect working order and white in colour. I have just changed to stainless. If anyone wants it let me know
Get my full license back in a few months which will mean I'll have another streeter, hopefully catch up with a few of you guys again on a friday night.
I'm trying to talk one of the Irish boys at work into buying your 180 lol
Oh no. speeding find, 6km over :( First one for me since 2000. Same road too!! (west tce)
My bad - must pay more attention to the cruising speed.
What would be good is a speed limiter that is adjustable. Press a button up or down to preset to a determined speed that the engine wont go over......
Sooo cant afford it, but you do the crime so do the time :/
Bad luck there Brendan - ironically I got my first fine since 1995 a few months back on a local connector road I drive every day.
But the answer is cruise control - and I use mine religiously.
  • Like 1
I had VDO speed alert in my R31, worked quite well, however you can buy GPS head units that have built in speed alarms - I got mine from China, $320 special...
-D
^^ E-go - we sent a Mitsi V6 to Brisbane a few months ago. Got a wooden pallet, used some thin steel bar and bits of 4x2 wood to bolt the motor to the pallet, then wrapped it in plastic (black wrapping plastic - bit like glad-wrap but thicker) & dropped it at the E-Go depot. Price was very reasonable, and it arrived with no problems. Paid a bit extra for insurance.
Im a wanted man these days Brad, will have to see what the go is
Whats the job we've bid for up there?
I might not get it if i need Electranet switching, ive been the only bastard to dodge that bullet and i actually want it haha
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
