I've had my second GTR for about 4 years now, and it's old. But I recently bought a daily in the form of a 2012 BMW, and not a garden variety model, but a rip snorting drivers car.
So when I was out with wifey a little while back on the backroads around Toolangi having a bit of a giggle in the new car, she says to me out of the Blue, " I know why you like this car so much, it's because it feels like your GTR!"
At that moment I thought how silly she is, this is brand new, current tech, completely different, but I thought about it a little, and she was right, it really does feel like my GTR. So my 2012 cutting edge driver's thingy feels like my old 1997 Nissan with 165K on the clock that surely has been thrashed regularly, I didn't know whether to cry or rejoice. Then I though, gee that old GTR is very good. Not only for it's age, but for just what it does and how it does it even by today's standards.
So recently I mentioned that I'm thinking of selling the new car, as much as I love it, for something more practical, just can't seem to fit much in it but me, or even a large eski. Wife said " why don't you keep that and sell the GTR" my response was "you've clearly gone insane, I'm never getting rid of this Skyline!!!"
So there you go, two signs that now I know I truly love this Skyline.
Cars are like females the older they get the higher the maintenance cost to keep em looking good
It explains the reason guys trade in the females and not the car, old cars are worth lots more haha
And its hard to find a low km female of age without a boot full of baggage and worn out carpet
(New BWM wow not after reading the horrors of repeated mechanical failures on one Last week )
950 for alternator geezus
250,000 dollar car now worth 15k crazy
Edited by Carbon 34
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
