Hi,
Just started a new R32 GTR Dedicated Rally Car build...
After putting Kermit into a concrete barrier in the rain last July, I am slowly getting the parts together to build another one..
Previous car straight after the "incident" with the wall at around 160 kph plus..
Then sourced the ex Brighty R32 GTR to use as the new donor shell c/w cage from Brad
Gave the shell a clean up-removed old stickers etc and then put on my trailer ready for Marc and Josh at C-Red to make it roll.. ready for Phil at AFM to ensure the chassis is straight-seam welding and panel and painting etc
Also purchased a Jun carbon fibre lip, CF wing and CF font grill as well as another set of original front guards/original bonnet and a new front radiator mount from Northside Nissan.
post-74499-0-47172000-1358252277_thumb.jpgpost-74499-0-66783900-1358252352_thumb.jpgpost-74499-0-28515900-1358252452_thumb.jpg
Once the car comes back from Phil at AFM ( panel and painted in the retro red white and blue Richards/Skaife livery)I will update with the mechanical details.
cheers
https://www.sau.com.au/forums/topic/417823-r32-gtr-drc-build/
  • 3 months later...
Interested to see how those door trims go. I have had my eye on them for quite a while but as you say, worried about them fouling on the side intrusion.
All looking great!
Hey,
Yeah, I have been looking at the Bee R door trims for a while and then one night after a few bourbs...I needed to have them....
I have attached a few shots I took this morning to give you an idea of what you get..( the doors are still off the new race car so I cant try them in situ yet...another week or so and i will find out)
The fit will clearly depend on the measurement between the intrusion bars and the actual body(ie: how wide the the tab is that is welded to the cage) if you follow me..
Drivers side and passenger side trims are around 50mm "thk"
Drivers side then slims down to around 30mm "thk"
Passenger side stays at around 50mm thk
Drivers side is about 30mm thk up in the top left corner, then blends up to 50mm thk as you get close to the door handle.
Note that both trims are 50mm at the top where they hook over the door....
Passenger is 30mm thk at top right corner then steps up another 20mm ( which makes it a pretty contant 50mm thk)
Driver top left corner
Driver bottom left
50mm thk where they hook over the door
Legendary! Thanks for posting this up will get the measuring tape out.
I wondered what happened to that car. Good to see it'll be revived.
Subscribed! Looking forward to seeing the old girl go round again!
You doing much racing these days? In a new car?
  • 2 months later...
  • 2 months later...
The car is now being set-up for 'Improved "Production Circuit Racing"
Going forward, I will keep a more up to date status of the build on my "basic" website..
ie:
It covers the previousTarmac Rally car info and the new build Improved Production car build as well as a sponsorship page
www.deleeuwracing.wordpress.com
  • 1 month later...
  • 1 month later...
Hey,
Its a no go to start with.....pretty expensive to just put them on a streeter etc so I am just about to "try" a couple of things with some mild heat and try to shape them in a couple of places....the drivers side just "touches" the cross bars so a smidge of heat just might do the trick ......but the passenger side( which has different shape-profile) might be a litlle trickier to re shape.....
I will let you know in the necxt couple of weeks.....
cheers
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
