There is a bit of talk about what mph a car should run at the drags with a given power output, thought be good to get sum results and discussion on this.
Be good to get sn idea of what mph a skyline should run with say
300rwkw
350rwkw
400rwkw
450rwkw
Etc.
So people post your mph results (1/4mile or 1/8mile, or both) and what power the engine made, and model of skyline.
Edited by sky30
https://www.sau.com.au/forums/topic/418443-mph-vs-power/
400awkw 11.3 @ 125mph
500awkw 11.2 @ 130mph
Full weight R34 GTR:- spent lots of dough to get 100 extra KW and only dropped .1 of a sec and picked up 5mph in the deep. ( both with 1.7 Sixty's )
Should have let someone who could drive have a crack. Seen an 11.007 @ 127 same car 350awkw.
https://www.sau.com.au/forums/topic/418443-mph-vs-power/#findComment-6721086
what time was that?
did you get half track MPH?
11.3 I think it was. It wasn't on the best surface. Half track NFI. I'll head back to the drags after my tune is complete and give it another go. Car has gone 11.1 previously.
https://www.sau.com.au/forums/topic/418443-mph-vs-power/#findComment-6721285
125mph and 400rwkw don't really match, power is certainly down there. Even @ 500rwkw you should be sitting 134mph EASY.
R33 GTR 340rwkw
11.5 @ 123mph
Full weight (full tank & spare in the boot) with a larger sump (9.5ltrs)/brakes/oil cooler etc + 85kg driver.
I wish I'd put it on the scales to see how much over factory with all the extras.
HR31 GTS-R 220rwkw @ 1480kg
11.9 @ 110mph
https://www.sau.com.au/forums/topic/418443-mph-vs-power/#findComment-6721318
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
