  • Replies 46
Do you plan on keeping the car after you have your full licence? If not maybe it is better to wait. Then you can get a turbo car and the world is your oyster. Turbocharged power is as good as sex. The advantage of turbocharging is that the pleasure comes whenever you put your foot down. The result of putting your foot down with a woman is a kick in the ballsack.
Edited by *LOACH*
https://www.sau.com.au/forums/topic/418483-fun-cars/#findComment-6721669
Do you plan on keeping the car after you have your full licence? If not maybe it is just better to wait. Then you can get a turbo car and the world is your oyster. Turbocharged power is as good as sex, the advantage of turbos is that the pleasure comes whenever you put foot your down. Putting your foot down with a woman results with a kick in the ballsack.
THIS X1000
https://www.sau.com.au/forums/topic/418483-fun-cars/#findComment-6721672
What about an MX5 or a hot hatch like a Renault Clio Sport?
Hell yeah, ol skool mx5 with the pop up headlights, nice set of fat jap lightweight wheels and some neg camber.
Touge to the MAX!!!!
https://www.sau.com.au/forums/topic/418483-fun-cars/#findComment-6722259
Definetly want something reliable, therfore newer. Need a non turbo as im still a bit under 2 yrs off fulls and my bro will take this car when i move onto a turbo skyline.
Basically something light and fun. Prefer coupe as well
MX5 is perfect besides the 2 seater hassle.
Is the Beemer myth real or not? As too the expansive parts and such?
Edited by ML73ZR
https://www.sau.com.au/forums/topic/418483-fun-cars/#findComment-6723040
n/a supra, vtec/engine swapped civics, teggy vti-r, prelude vti-r, 3s-ge sw20 mr2, aw11 mr2 if you can find one, manual mivec fto, silver/blacktop 4a-ge levin/trueno.
That'd be my shortlist.
Or you've got the classic trashed q's silvia etc
https://www.sau.com.au/forums/topic/418483-fun-cars/#findComment-6723152
My 2c, buy a te/tf crossflow 6 powered cortina backed by the single rail borgwarner 4 speed box.... Extractors exhaust inlet manifold Holley decent tires will see a 14 second 1/4 enough to walk alot of stockish turbo imports and older v8s.
Bigger cam solid lifters valve springs port work better clutch minispool 90/10 shocks and say hello to a low 13 second (possible 12 second) p plate "legal" street car.
(There is a guy running in the 11s on an NA [no nitrous, turbo/supercharger] cross flow powered td cortina in qld... http://m.youtube.com/#/watch?v=ACor769AAoA&desktop_uri=%2Fwatch%3Fv%3DACor769AAoA&gl=GB)
Sky's the limit with them bro, just watch for chassis rail rust and bad shells
Edited by Captain Natro
https://www.sau.com.au/forums/topic/418483-fun-cars/#findComment-6725050
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
