Aussie VIN number - done
High Mount Brake light - done.
A few other ADR items like tyre placard, fuel filler neck, unleaded only fuel sticker etc also done.
It's been a good start to the weekend so far. Godzilla is 25 years old this year. That means - Club Permit!
Finally road legal after 9 years of arriving down under.
  • Like 3
Looks great and gets better every Pic
where did you get the high mount brake light from and are you happy, is it secure enough ?
I bought one similar and the first hot day the double sided tape let go :( (POS)
Edited by Sinista32
Thanks mate.
Light is a Narva 84650BL. Came with 3M double sided tape & the LED's can be angled. Hope it isn't the same one you tried that fell off :)
Autobarn stocks them.
http://www.narva.com.au/products/browse/eye-level-brake
I tried to get a Hella 5237 multiple times from the local Repco but gave up as they didn't get back to me multiple times.
Thanks - *nervous look* It is the exact same one and they're ADR approved. I bought it from Repco.
may have been the way I applied it though I did use prepsol on the glass first. It was about 38 degrees and in the sun all day. So a 50/50 chance.
If it does fall off on a hot day Wurth make a brilliant industrial strength double sided tape. :thumbsup:
Hmmmmm. I'll see how I go with it. I'm planning to replace it with the Hella down the road anyway
Thanks for the tip. Is the Wurth double sided tape good for side skirts etc too?
Do tell :)
race tune.
Currently on my setup I'm making 350kw at 20-22psi on the -9s with 98pump fuel
This is the everyday tune that is also safe on the track as I track my car a lot now
I have been told by my tuner there is more in them but not with 98
E85 maybe this year but I do daily my car, just got a new car for daily duties this month so we shall see
There is heaps of potential in these turbos if your setup is good enough, they won't crack 400 but when you have full boost by 3800rpm who cares haha
Wow and I thought I was up at odd hours on this forum :)
Something to consider (and this has been done to death on here), the only way to truly compare is to have the cars on the same dyno, on the same day, with the same wheel/tyre combo. At the end of the day 350rwkw is awesome on -9's.
btw do you have a dyno graph of your final run?- I'm more curious about the boost curve on these turbos as I know my setup was modified to hold more boost so wanted to see what they do on the top end on different setups.
On night shift this weekend ?
Yea I know all dynos are different and tyres blah blah
Numbers don't mean much to me all I wanted was something reliable with some power
I'll find the dyno sheet and post it up
They do drop off in the top end, that's just how the turbos are
Edit
329 run
B904E5CD-A205-4487-AB5D-DFBD41AF5104-568
350 run with stuffed cat screwing the top end, will go for another run next service I think
8A48BB11-9718-4233-9092-94AC91FB0942-568
Edit
329 run
Nice. What gear - 3rd?
Ditch the cat :)
Loving this build. Keep us updated!
Thanks mate. Will do :) Still so much to do!
Went down to Apollo Bay yesterday with an old mate of mine. Covered around 500km's and she ran well all day, even through the unsealed roads we came across accidentally. Got to pretend it was a rally car for a short while. They both got a tad dusty.
1913442_10151983953867734_1189276120_o_z
Livin the dream, You didn't go down Wild Dog Road, just before the entrance to Apollo Bay did you? Love that Road.
Also, are you planning on coming on the SAU Apollo Bay Cruise in a couple of weeks?
Hah! Yes we did :)
I now understand why it's called Wild Dog Road.
Hmm possibly, man.
It's a bit rough but an awesome drive. Great views once you get to the top.
Looking forward to it. It'll be the 1st time I've taken the car down the GOR since I bought it.
Hi Shivam, I'm the guy from Perth who approached you & your mate while you were resting up in Apollo bay on Sunday.
Found your build thread you were telling me about - good work! It was nice chatting to you fellas. I'm definitely missing my car after a few months away from home as you could probly gather by the way I chewed your ears off!
Enjoy the car after all the hard work mate. You never know I may meet you again later this year if the SAU Nats are held at Phillip Island!
Wes
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
